Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Paper jam The printer gives a paper jam error after printing one page. There never has been a paper jam. The machine has to be opened multiple times before the paper jam warning clears.
  • 85 Answers
Which type of ur printer is it lazer or inkjet . if it is lazer printer chack the teflon rod . and if it is inkjet printer clear its sancers
Posted on Jun 03, 2008
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Canon Imageclass MF4370dn constant paper jam errors
Dear
Inside the back panel there are paper sensors attached to lever, a small spring connected to lever to keep its home position, the spring may dislocated from its position or the lever sticked to the base. some times a small piece of paper sticked at this may cause the problem.
Thanks.
Apr 20, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
HP 4200 printer paper jam. No paper is jammed
OK, if the printer says jam but no paper inside and prints after you open and close the cover the paper likely never made it out of the tray. Or the machine thinks the page never made it out of the machine.
As far as input check your rollers 1 in the tray and the pick up roller in the machine if you don't have alot of pages on the machine these likely OK.
Next (and this I have found often) check the paper back stop in the tray. This is the guide to set the length of paper. If it is set just a little long the roller cannot catch the edge of the paper. Sometimes the teeth the guide sets in are broken or worn.
The output would be the sensor in the fuser replace fuser.
Hope this helps
Feb 19, 2009 | HP LaserJet 4200 Printer
Printer says paper jam and stops- but it is not jammed
your description indicates you need to thoroughly check printer for any bit of paper ........rolller too has to be checked so that paper is moving smoothly ......
Feb 02, 2009 | Brother MFC 420CN All-In-One InkJet...
Paper Jam
hi y'all -
you share a frustrating problem... error message but no apparent error (jam)! it's one that's common to many models of printers and the result of many different causes.
I've seen it when I've printed on cheaper paper, or different (lower) grades with odd surface finishes. the sensors get dirty, or the printer/computer 'thinks' there's paper stuck where none exists. I've opened/closed paper trays 2-3 times and rolled feed rollers around multiple times, then closed printer paper drawers only to have the 3rd time of doing the exact same steps be the time it cleared the error message.
there are often very tiny pieces of paper stuck in weird places in the paper path in printers, too. if you did have a jam before the message started, is every little scrap of the page accounted for? there are also hard to get to places to find paper scraps in larger printers, but I'm going to assume you're all talking about home printers.
here are a few general HP support links you may find helpful for future paper jam messages for this model of printer.
this link is for general info for this model:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&product=304535&lc=en&jumpid=reg_R1002_USEN
this link is for general support for this model:
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&dlc=en&cc=us&product=304535
here's a link addressing paper jams in general:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09189&lc=en&dlc=en&cc=us&rule=26353&product=304535
and here's one on cleaning your printer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00016484&lc=en&dlc=en&cc=us&product=304535
hope this helps a little bit for future refs. remember that using good paper helps print quality and lessens printing problems. also, when you take a stuck page out of a printer, doing so gently will help ensure little scraps of paper do not tear off paper edges and get stuck in weird spots. it some times helps to gently, manually, roll the feed rollers a full turn around in the printer, too. patience pays! -JW50
Sep 02, 2008 | HP DeskJet 3650 InkJet Printer
Paper Jam
try a test page..and see if that flows..
Aug 20, 2008 | HP LaserJet 2100 Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Dell printer problem
Sounds like you may need to replace the pick up rollers on the machine.  Without knowing exactly where the jam error happens during the print process, it's hard to say.
Oct 19, 2007 | Office Equipment & Supplies
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
284 people viewed this question
Ben Johnson
