Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Problem turning On
Golfmex79 on May 18, 2008
We have a Samsung HL-P5063W DLP TV. Lately it will not turn on the first time the remote is pressed, in fact it seems to take longer and longer to come on. Sometimes the timer and the lamp lights blink on and off for a while and then all three lights blink and the standby light comes back on. After pressing the On button on the remote and going through this process a number of times, it will finally come on. The picture looks good. the set is three years old.
Any guidance would be appreciated.
Thanks!
Harry Have a samsung hln617w, supposedly not listed, lamp was burned out so I purchased replacement. Will not turn on. Can hear two efforts and then auto turn off. Have read where others have same problem and tv eventually turns on. New lamp, another problem, not cheap either as I did not have a running spare purchased economically. Could use some help or direction, dont want to purchase additional to see if new purchase was faulty
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Jun 04, 2008
-   I bought a 43" Samsung DLP 4 years ago and I"m having problems with the tv. Sometimes when I try to turn the tv on it will not come it cycles on and off and finally the lamp light comes on and the temp light comes and stays. Sometimes I keep trying and some times it comes on and sometimes it won't. Is it the problem with the lamp? Anybody has a solution? -   kmysore2
Best Solution
posted on Jun 09, 2008
Very Helpful)
Russmann
Rank: Guru
Rating: 89%, 68 votes
The lamp, ballast or dmd board can cause the same problem. Most commonly on these DLPs it is the lamp, but we have to use the process of elimination as well sometimes. Even as a samsung warranty center sometimes the flow charts don't help. The first thing I would do as a consumer is to vacuum around the ventilation holes behind set, these can cuase poor circulation and startup/shutduwn problems. Then with those type of lights flashing start by bidding for or buying the most inexpensive lamp you can get. Make sure exact replacement. Do not touch the glass on lamp when replacing. Then try the ballast which also has a part number on it and has only two screws when you have lamp removed from set. If still no luck, assume it is the dmd board and try pricing that baby. Not cheap! Then comes the decision. New set or repair this. This is what you can expect unfortunately. But I have the same set at home. Go figure.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jun 04, 2008
Not Rated)
tvrepairguy
Rank: Wiz
Rating: 82%, 191 votes
use no sub's OEM only!
Was this helpful?
Yes
No
Related Problems
This occurred after I replaced my color wheel and lamp. All...
TV worked fine the last time used. Now when I turn it on it...
Samsung DLP HLN61W tv when i turned on i just get voice and...
Can you Help with these Projection Television problems?
Samsung HL-6761W
Solve
The upper 3rd of the TV screen lost color. Its all one picture but the upper portion is in grat... (More)
My Samsung DLP hlp4663wx/xaa TV has...
Solve
The picture has just suddenly scrambled on my Samsung DLP hlp4663wx/xaa TV. I turned it off for a... (More)
no sound from samsung hln617w
Solve
is ther a way to disable the speakers? if so how do i turn them back on?
SAMSUNG MODEL HLN617W TURNS OFF BY...
Solve
This television will turn off by itself after being on for a short period (3 or 4 minutes) I was... (More)
Color wheel on DLP rear projection...
Solve
I own a Samsung 60 inch DLP rear projection TV--Model Number HLN617W. After my wife heard a very... (More)
Sponsored Links
Describe your TV & Video problem:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(407) 952-4048
WE REPAIR ALL BRANDS TV-BIG SCREEN-PLASMA-LCD...
        JR  ELECTRONICS
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
