Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Colour problems the colour on my Tv is only red and pink Hitachi 50/500 redness problem and nightmare original problem, turn on the television and everything was red. First step in resolving original problem. Replace Hitachi ux21511 Lamp with OEM replacement. Did not solve the problem picture still red or pink. Went to start menu and hit reset button hoping to set everything back to factory position. Had absolutely no effect. Try to manually reduce redness, contrast, and everything else that came to mind through the controls. Nothing that I tried using the controls failed. Out of ideas and patients, hope you have a solution for me.
    Brigadier General:
  • 6,966 Answers
Any developments with your Hitachi?
Posted on May 18, 2008
3 reasons for this.
1st reason the fluid is contaminated and thats why u dont get red.
2nd reason no red drive possibly due to a bad colour driver on the base of the tube neck.
3rd reason the tube is out.
May 23, 2010 | Hitachi 43FDX15B 43" Rear Projection...
My picture is now always a pink to red shade on my
unplug your TV look on the back for a three controls marked red / blue / green "screen" turn / tap on them; watch the screen when you find the "dirty" control clean it with "TV tuner cleaner spray"
Mar 20, 2010 | Hitachi 57UWX20B 57" Rear Projection...
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Aug 31, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Pink colour everywhere
Assuming all power supplies are OK, you most likely have a bad CRT grid, and that respective (red) tube must be replaced. I'm sorry that it went that way, as this repair is not cheap....accordianman
Sep 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Colour tv
problem cuold be red crt or red video output circuit or screen control set too high. Should have tv tech check it out.
Jun 12, 2008 | Hitachi 43FDX01B TV
Colour problems
try to go in menu do factory reset ok
Feb 03, 2008 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Colour issues
Sounds like your red gun may be shorted, Try adjusting the red gun down a little see it that helps.You can also switch the blur CRT socket for the red if your screen is still mostly pink then you know for sure its your red tube that needs replacement. If its mostly blue then you have a problem in the red drive circuit.
Jan 14, 2008 | Televison & Video
Hitachi 43FDX01B (convergence) problem
Convergence IC's must be changed to start repair..original...
STK392-110 sub to Hitachi upgrade STK394-160E.....PART #
CZ need two....
Next, take a critical look at the B+ feed resistors near the IC's..
check for over-heat / damage......usually 2.2 ohm 2 watt......
Let me know....................T.
Jan 03, 2008 | Hitachi 43FDX01B TV
Picture problems
CRT green gun is not working properly , maybe dry soldered or no green drive signal. Pink and red colour is due to missing of green colour.
Sep 09, 2007 | Sanyo DS27820 27" TV
Hitachi 53FXD20B Spots with colour
take your tv to a tech and have them check your tv the color module could be the problem or the the convergence module.good luck.
Apr 18, 2007 | Hitachi 53FDX20B 53" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
150 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
