HI WEATHER YOU NEED TO SPLIT THE FORKS OR NOT, YOU SHOULD, SOME OF THE OLDER HONDAS REMOVING THE LOWER FORK BOLT, ACCESABLE WHEN THE SPIINDLE HAS BEEN REMOVED, THIS WILL DRAIN THE OIL OUT OF THE FORK LEG THERE WILL BE A WASHER OR SEALING RING ON THIS SO BE CAREFUL NOT TO LOOSE IT WHEN YOU REMOVE THE BOLT, USING A BOWL OR CONTAINER TO CATCH THE OIL, UNDO THE BOLT IN THE LOWER FORK LEG, AFTER ALL THE OIL HAS BEEN REMOVED, PULL DOWN ON THE FORK TUBE IF THIS PULLS OUT OF THE LEG THEN YOU CAN COMPLETE THE JOB QUITE EASY, REMOVE DUST SEAL, CIRCLIP AND OIL SEAL, THE LATER WILL BE QUITE TIGHT IN THE LEG, WHEN YOU EASEMBLE THE FORK YOU WILL HAVE TO UNDO THE TOP FORK NUT TO REPLENISH TTHE OIL
