Question about Kenwood KRF-V5060D Receiver
Rear speakers dont work
I cant seem to get the speakers behind us to work. We have gone through the speaker set up and done what it says, they work on the test but not when we play a dvd/aux etc.
On the display it only has the L & R speakers lit up....the subwoofer and middle speaker work ok but not the other two.
Ive done the factory reset thingo, they wont work and it still only has the L&R on screen .
My 18month old has been pressing a few buttons......maybe he's done something.
Can anyone help. Please
Vicki
PS My hubby assures me everything is plugged in correctly.
    Genius:
  • 1,148 Answers
CHECK THE DVD PLAYER SETUP AND THE RECIEVER SETUP,,IF YOUR USING RCA JACKS ,,THEY WANT WORK,,,OPTICAL CABLE OUT ,,I WOOD USE THAT ITS THE BEST
Posted on May 15, 2009
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
REAR door speakers dont work in 98 gmc c1500 suburan
Hi, generally when you a buy a car, the steroe and speakers are all stock fitted, if bought second hand, they may have been upgraded.
Down to your speakers, check connectors behind the steroe unit, should be 2 plugs, one for power with red, black, yellow and blue wires, and the other plug is your speakers. Check there is 8 wires into the plug.
If all is correct then check the rear of your speakers, check the connection and that the wire isnt loose.
If all is fine there must be a wire break somewhere, your stereo presets are only set to the front speakers (fade setting).
Hope this helps
Mar 08, 2012 | Car Audio & Video
Car front two speakers arent working. rear two are.
have the front speakers ever worked?
if not have they been connected properly?
if yes then
look under ballance and check theat rear and front ballance is in the middle
if it is then for temporarily replace the front speaker with any old speaker
if that works then you need new front speakers
if no then the radio is broken
but what you could do is rewire the back speakers so they also play though the front ones too
this can be done from behind the radio
find the rear right positive and negative wires
strip the insulation but dont cut the copper wire
cut the front right speaker and attach that to the rear speaker wire
do this for both positive and negative
rear right
positive
..v
..v
I...I
I...I
I...I
.I.I..........< strip cable but do not cut metal
.I.I..______________
.I.I=_______________ <<<front right positive
.I.I
I...I
I...I
I...I
I...I
Jan 06, 2010 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Rear speakers dont seem to be loud. The front speakers are projecting most of the sound. How do I get the rear speakers to project more sound?
Your settings in the receiver are not set up properly.
You need to adjust the volume output through the rear channels in your receiver.  Review you manual for set up. The issue is in the receiver, not your speakers most likely
Sep 24, 2009 | Coby CSP-94 Speaker
Radio Speakers
Its possible that some wires are loose, considering both rear speakers are not working and not just one. Your best bet is to check for any loose wires behind the front deck or behind the rear speakers.
Apr 15, 2009 | 2001 Mazda Protege
LG flat screen TV speakers make a vibrating noise
I have this problem with my 37LG30.
They all seem to have the same factory flaw.
The plastic bezel and rear is vibrating against itself I have found.
Tonight, just now, I just took all the front bezel screws out,(from the back) loosened the other 4 big screws in the rear center(I don't recommend removing them)and loosened the stand screws also and tried separating the bezel from the back as I went around the set. This did not really help much except around the bottom where the noise/vibrating comes from-the speaker area.
The two plastic pieces are vibrating against one another.
The vibrating was coming from the speaker area without doubt.
The next thing was to try separating at the bottom where the speakers are with my fingers and a stiff metal nail file carefully..fingers seemed to work best for me.
As I separated the front bezel from the rear housing (at the speaker location)most if not all the buzzing/vibrating /distortion went away.
I then inserted small pieces of cotton (you can use felt, or similar I suppose) and buttoned it all back up;put the screws in
Almost all the distortion and speaker buzz/vibratingis gone except on very low frequencies.
good luck!
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
I have acer al1917w A monitor but no sound
There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
Jan 09, 2009 | Acer AL1917W LCD Monitor
check all your speaker wires probably they are broken.if they check good then you will have to get a tech to look at your set it could be your set output ic or transistor gone bad and need to be replaced.and if it is a old set buy a new one probably it wont worth the while to repair it.
good luck
Aug 17, 2008 | Onkyo TX-SV535 Receiver
Rear speaker connection issue
OK, the fix for the missing rear speaker sound on the DELL WL6000 5.1 Surround Speaker System is relatively simple, just 7 simple steps (Verified by Dell at http://support2.jp.dell.com/docs/acc/P121646/multlang/srg/DAO/srg_dao.pdf..
First, power down everything. Second, disconnect the rear speaker and subwoofer from the power source and wait about 5 minutes. Third, be sure the power switch is off on subwoofer and the center speaker. Fourth, plug in the power for the subwoofer but DO NOT turn on the power yet. Fifth, plug in the rear speaker power cord. Sixth, turn on the swtich on the subwoofer (this is the start of the resync mode). Seventh, turn on the center speaker power and the system will change the rear speaker system LED from flashing blue to solid blue in 5-8 seconds. The surround system is functioning again. You may test this under sound in the Control Panel but I would prefer to use a modern music CD that has Dolby Digital Support for 5.1 sound or better. YOU WILL HEAR INSTANTLY THE SOUND DIFFERENCE WHEN THE REAR SPEAKERS ARE CONNECTED.
Nov 10, 2007 | Dell WL6000 Computer Speakers
Kenwood KRF-V5060D Receiver Logo
191 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
