Question about Mitsubishi WT-46807 46" Rear Projection Television
TV is Ghosting
My TV is showing Halos or Ghosting I don't no the correct term, But some one told me that it is the Convegence board. If it is. Is there a way I can fix it myself or do I have to call a repair man.
Model: Mitsubishi WT-46807 46 inch Rear Projection
    Scholar:
  • 131 Answers
If convergence problem color would be bowed and off. If it is the convergence replace ic stks there are 2 inside tv if you could solder and good at this stuff. parts cost is 30.00 . if you are going to get fixed cost is 300.00 . www.part store.com has parts just give them model number .They can tell you part number.I would pay someone to do this it is trickey.
I think ghosting is ground problem on cable connections check connections and replace cable wire.
thanks doctor video
Posted on May 18, 2008
Ghosting lines on a samsung LN40A630M1F
The TCON Board or the LCD panel is faulty. Can confirm only by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 16, 2016 | Samsung Televison & Video
TV rca hd 52w59 has convex picture. can I fix it.
If convergence adjustment did not correct the problem likely the convergence IC's have failed and will need to be replaced along with a few defective resistors in that circuit. If you have never attempted TV repair this would not be a good repair to start on.
The only way to be positive of the problem is to have the circuitry diagnosed by someone with the proper TV test EQUIPMENT to determine what parts that are no longer within specs.
KEEP ME UPDATED..
Sep 29, 2008 | RCA D52W19 52" Rear Projection Television
Screen show a lot of green ghosting throughout
I had the same problem and removing and replacing the T-Con Board fixed it. I purchased the board from ShopJimmy.com for $59.16. P/N 6871L-4550A T-Con
Apr 04, 2013 | Vizio VF552XVT 55" inch Class XVT Series...
Hello. I contacted you earlier, your email went to my spam. I missed it and cancelled . Sorry. The problem. I have is a ghosting picture of a program I watched earlier. The problem comes and gos....
Good day!!!
Sorry but I can't see any previous questions from you to my email but anyways lets proceed to your problem..
If you are watching TV shows and the picture is ghosting kindly try to play a DVD movies or anything that having video on your DVD if the picture is fine when you play a DVD movies your TV is in good condition you don't have to worry about..If the picture is fine when you play a DVD let me know and I will give you next step of troubleshooting..
However if you play a DVD but still picture is ghosting there something wrong with your TV..
If you are using DVR then when you back to TV it become ghosting..It is possible that you hit the wrong button on remote..you can also try to restore factory settings to correct all possible wrong set up and also to to auto scan your TV to get back all channels clearly..
Hope it helps..
regards,
chester
Jan 25, 2012 | LG 50PC1DRA 50 in. Plasma Television
Double lines
Tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B are mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead to caused these problems.The tv convegence board must have be repair like repalacing parts like 2 STK convergence ICS and some or all of it resistors too.To repair the tv convergence board to solved tv convegence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 25, 2011 | Sony KP-51WS510 51" Rear Projection...
The picture started getting a triple image (everything was outlined in blue and yellow). We had a board replaced by a tv repair service, over $300 and the tv was ok for about 80 hours. (warranty on new...
Ur tv convergence board that was replaced for ur tv.The 2 STK convergence ICS was old it is not new it is those 2 STK convergence ICS on the tv convegence board is dead again and some of the resistors on the board maybe shorted and dies also must replaced too.The tv convegence board was put on ur tv those parts on the convergence board are old components parts,ur must repair tv convergence board again to fixed this problems called convergence pictures problems.
Aug 22, 2011 | Mitsubishi VS-60609 60" Rear Projection...
Convegence
Yes - about every 4-5 years.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 18, 2010 | Televison & Video
Samsung tv model # HCP4363WX Ghosting
The convergence board that you replaced will not correct the issue that your describing as your model has the convergence amp circuits located on the Deflection board. You would need the deflection board which is available at the following link. It also has a picture of the board which is in your model its the large board on the right with the Flyback and both Convergence ICs on it.
http://servicemanuals.vstore.ca/product_info.php/pName/p59a-pwr-def-board/cName/samsung-parts
Dec 16, 2009 | Televison & Video
Blue color
as far as alge ...i cant comment on that. it just sound like your blue tube has quit altogther/...yes they can be quite expesive..however it could be crt board..maybe...buy you a new one...LOL
Dec 06, 2007 | Akai PTH5498 54" Rear Projection...
51 projection tv dark colors
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 20, 2007 | Philips Magnavox 51MP392H Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
