Question about HP PSC 1610 All-In-One InkJet Printer
HP DESKJET F21OO ALL-IN-0NE SERIES PRINTER
When i first started using this printer - all the features works fine..but now, for some reason, the scanner stops working, normally, when i press scan button, it starts scanning but not anymore.
would deleting the printer from my windows vista and reinstalling it again will take care of this problem?
your feedback is appreciated..
thanks..
grace
  • Anonymous Sep 20, 2008
    thank
  • yasserstaf Nov 29, 2008
    thxxxxxxxxxxxxxx
    Guru:
  • 731 Answers
Hi
Please try the following steps to resolve the problem:
*********************************Step 1************************************
1.Right click on Computer ->Properties->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+)
sign.
4.Check for the "USB Composite Device" and right click on it, click
Uninstall.(IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB
COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE
DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for
wat location says, (Eg -LOCATION : HP DESKJET F2100)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new
hardware".Then the Drivers will be installed Automatically.
(If this doesn't works go for step2)
*********************************Step 2:*********************************
1.Click start - > in start search then type "twain_32" click OK.
2.A window will open and click EDIT menu-> select all, then delete all the files and folders.
3.Click start - >start search then type "services.msc" click OK.
4.Look for service called "HPZ PML Driver", Doubled click on it, check whether the "startup type" is "Automatic", if not changed it to automatic.Checked the "Service status" is "started".If not click on "start" button.Click Apply and OK.
5.Right click on "HPZ PML Driver" and click "Restart".Close the window.Click start - >run then type "%temp%" click OK.A window will open and click EDIT menu-> select all, then delete all the files and folders.If u cant delete them its ok, just close the window and go to step 6.
6.Disconnect the Printer USB cable, Insert the installation disk of your printer.If Installation wizard pops up, click on cancel/exit.
7.open Computer, right click on your CD/DVD ROM Drive , then click "open".Look for folder called "UTIL" then look for folder called "CCC".There you will see a file that says "Uninstall_2". Double click on that file.
8.A run box will poppup, click OK, now you will see the command windows, hit enter the Driver that is necessary for comunication which are corrupted will be removed.
9.After that, restart the PC and Insert the Disk and install the printer.Connect the Printer USB only if the PC prompts you to connect.After installaton completes, check the scanner.
(if this doesn't works go to step3)
*********************************Step 3:*********************************
Using the CD, uninstall the printer or you can also uninstall using the Programs and features.Then Reinstall.
(Note: During uninstallation USB must be disconnected)
Thanks
Riz
Posted on May 19, 2008
How can i download hp deskjet f4288 all-in-0ne printer software and driver
Hi abhayjack,
You may download your driver software, click this link http://www.siliconguide.com/drivers/device/1180/.
After download completed run the set-up, then follow the wizard.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 17, 2011 | HP DeskJet F4280 All In One Printer InkJet
Hi I have an HP Deskjet D2560 which was working fine up and until I installed my new HP Deskjet F4480.Ever since I keep getting an installer plugin error that keeps popping up for the D2500 series printer ...
Try making the other printer offline when ever not in use. Their could be reason this is clash of installed files or else try uninstall of D2500 printer drivers & installing with updated drivers that can be downloaded from support.hp.com.
Oct 31, 2010 | HP Office Equipment & Supplies
I need to know if I can send a fax with my HP deskjet F2400 all-in-one series printer-scanner please...
The HP Deskjet F2400 model printers are All-in-One which will let you Scan/Copy and Print but they do not have the Fax feature.
Oct 09, 2010 | HP DeskJet F380 All-In-One Printer
I want a software for my printer.
No Problem! Just go to HP.com/Support and download it.
There is one thing, however. You must get THE software for YOUR Deskjet. HP lists four different models for the Deskjet 5650 series. The 5650, the 5650w, the 5652, and the 5655. The software MAY, be the same for all models of this series, but I don't take chances, and give erroneous information.
Viewing the Deskjet from the front, the model number is on the lower right side.
Here is HP.com/Support, the page for the Deskjet 5650 Color Inkjet series, and the specific page that you choose which model you have,
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_query=Deskjet+5650&submit.x=3&submit.y=2
I'm going to click on the top model listed, HP Deskjet 5650 Color Inkjet Printer,
as an example.
Now click on the -> Software & Driver downloads heading.
Now choose which Operating System you are using.
I see they only have the Diagnostic Utility available, if you are using Windows Vista.
If you are using Windows XP, they have the full software package available.
(HP Deskjet Full Feature Software and Driver -Date: 12-2003)
Jul 12, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
Printer will not print
Disconnect and turn off your printer.
Search by your printer model number and download latest drivers from here:
http://h10025.www1.hp.com/ewfrf/wc/siteHome?lc=en&dlc=en&cc=us
Start installation of drivers and connect your printer ONLY when the setup asks to connect your printer.
If it gives you any warning about "driver signature", just click on "continue anyway". After completing the installation, your printer will work fine.
Jan 05, 2009 | HP DeskJet F380 All-In-One Printer
Whether my printer is a LASER printer
You can call hp tech support toll free number - 1-800-585-2494 and they will give you all information regarding to your printer. for more information you can visit: HP Customer service .
Hope this will help you better.
May 22, 2008 | HP DeskJet F380 All-In-One Printer
Using JETCET Print with OKI C5200n Printer
The OKI 5200 is a 'GDI' or Windows only printer and does not support PCL or PostScript languages.
Most if not all of the printers listed support either PCL or PS or an inkjet based language.
I'm afraid you will not be able to print the the 5200 without it's driver loaded on the PDA.
If the 5200 supported PCL you would be able to choose any of the
Color HP Deskjets.
Oct 15, 2007 | OKI C5200n Laser Printer
HP PSC 1610 All-In-One InkJet Printer Logo
639 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
