Question about HP Compaq Presario V2000 Notebook
Computer turns itself off
Compaq V5101AU turns off after about 10 mins when not in use. Power light stays on. Settings have been checked and are OK. Have run Spybot, have Semantec current, Zone Alarm. Could a bug have got through and changed settings??
Help
Thanks
John
    Champion:
  • 207 Answers
Check the same in safe mode and bios one by one
keep ur computer in safe mode desktop for atleast 20 min
and teh same in bios if it is restarting in the bios and the safe mode also motherboard needs to be replaced ...if not do recovery from the cds
Posted on May 19, 2008
Sandstrom HD LED tv
hi this could be a capacitor in the power supply, they usually bulge up causing faults like this , look for tv tech in your area, good luck
regards
shaun
Jan 06, 2014 | Televison & Video
My hp compaq nc600 laptop wont turn on just an ornage light comes on, black screen and fan for 10 seconds then dies?
In the first instance you need to check your power lead. Exchange it for another one that you know works.
Apr 09, 2013 | HP Compaq nc6000 Notebook
MY COMPAQ CQ56-129NR when turn on the power light comes on then cap light blinks but no start up screen. Screen stays black what can i do if anything?
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
Jul 21, 2011 | Computers & Internet
I have a compaq presario CQ61 and i turn it on and everything works but my scrren stays black. what is the problem?
HI
First of all if you can remove the ram memory DO IT SO ifyou cant try without removing FIRST.
-remove battery pack(if you can romove memory ram aswell) and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILLSTART ONCE YOUR SYSTEM BE READY SHUT IT DOWN PUT THE BATTERY PACK BACK ANDCONTUNUE TO USE YOUR LAPTOP
Feb 26, 2011 | HP Compaq Presario CQ61420us Notebook
Hi my hp 6735s laptop has just started turning itself off when knocked or moved slightly. When you try and power back up the orange light around where the power lead plugs into the laptop flashes about 10...
Check the power cord at the connector. Hp has a problem with the cords breaking internally. I had a problem with mine and found that if I played with the cord then it worked for a while. I ended up buying a new power supply.
May 26, 2010 | HP Compaq 6735s Notebook
Compaq Presario sr1000(sr1430NX) will not stay powered on
Hi!
Please check for the cables coming into the motherboard from the power supply. Also try and check for any loose cables.
If that doesn't help then please get your power supply changed as its faulty.
Please rate this solution.
Thanks
Rylee
Feb 11, 2009 | HP Compaq Presario SR1430NX (PS566AA) PC...
It wont stay on
Hi Kimberley,
Looking at your brief description of the problem a possible fault may lie with power supply and or battery.
Have you access to another Armada power supply? if not does the light go green when Pc is turned off and fully charged.
I would be looking in these area's for the problem.
Good Luck,
Paul 'W'
Onyer~EDson(:0) {#><U.K.
Jan 15, 2009 | Compaq Armada E500 Notebook
Power start up itself after 10 mins
Check you start up settings it may be set to start from keyboard mouse or modem plus others even in the BIOS
Aug 08, 2008 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Computer keeps shutting off
The problem more likely seems with the power supply or the front power button. Donnot try switch on the computer again and again it may cause damage to the motherboard. Use the following link to pin point the problem.
http://tinyurl.com/5bbrxc
Thanks
Proton
Do remmber to rate the solution if it was helpful or fixed your problem.Thanks for using fixya
Jul 05, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Computer shutting down
do you get a blue screen when it shuts off? or... does the monitor just turn off, or does the computer tower and everything turn off?
If everything turns off,(like a normal shutdown) try checking your power options in the control panel, to make sure there aren't some power saving settings that are causing it.
If its a blue screen type issue, then there may be a hardware problem that is causing the computer to shutdown to avoid further damage to the system.
Jun 27, 2008 | Acer Aspire T120 PC Desktop
HP Compaq Presario V2000 Notebook Logo
64 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
