Question about Siemens SpeedStream Modem (4100) (SS4100)
Changing the MTU setting
I'm having trouble connecting to xbox live and it's keeps saying that the minimum MTU setting needs to be 1364 and anything less than that won;t work. i have the ethernet plugged in directly from the xbox to the siemens speedstream 4200. how do you change the MTU setting to something that will meet or exceed requirements of xbox live?
  • 6 more comments
  • greenman0987 May 18, 2008
    when i type that into my browser it doesn't let me log into the modem it just acts like a search and gives me google results for it or something. am i typing it into the wrong browser or something?
    the way to log onto this particular modem was to type speedstream into the browser in case you need to know in the future i think i can fix the problem now that i can access the modem utility
    thanks for all the help.
  • Anonymous Aug 24, 2008
    mtu failed on xbox connection
  • foxracing191 Sep 29, 2008
    i'm having trouble connecting to xbox live and it's keeps saying that the minimum MTU setting needs to be 1364 and anything less than that won;t work. i have the ethernet plugged in directly from the xbox to the siemens speedstream 4200. how do you change the MTU setting to something that will meet or exceed requirements of xbox live?
  • cubsrule7299 Sep 30, 2008
    i have the same problem only i have the wireless usb plugged into my xbox
  • braman68 Sep 30, 2008
    i need to change the mtu settin how do i do that?
  • duncan2008pi Nov 15, 2008
    how do you change the mtu setting
  • Anonymous Jan 25, 2009
    my x box live wont work becaus of my mtu how do you change it
Thz
Posted on Nov 17, 2008
How do you change the mtu
Posted on Nov 15, 2008
    Guru:
  • 1,342 Answers
Log into modem using 192.168.2.1 in your browser and go to modem utility through browser.
Posted on May 18, 2008
Tip
Xbox Live - MTU Error
Xbox 360 MTU errors
This issue occurs if your router or the gateway is incompatible with Xbox Live, or if your router or the gateway has an incorrect MTU setting. Note: Xbox Live requires a minimum MTU setting of 1364. We recommend that you try out the steps shown below.
Things to try:
1. Ensure that you have properly setup your connection to Live by using the Connectivity Wizard http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/webconnectivitywizard.htm
2. Visit the following Web site to determine whether you have the correct firmware version that has been certified as compatible: http://www.xbox.com/en-US/live/connect/routerlanding.htm
3. See the router or gateway instruction manual for information about how to change the MTU setting to 1364, to do this, or to determine whether your router supports this feature, see the router support documentation or contact support for your router device.
4. If you share a connection with a router and a modem, try a direct connection without the router.
For additional information on this topic refer to the following KB article: http://support.microsoft.com/kb/908882/
on Sep 30, 2008 | Microsoft Xbox 360 Console
How can I change my mtu on my wireless router to be able to play xbox?
Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Learn how to find and use your router configuration page
Look for the MTU setting on the router configuration page. When you find it, set it to Auto or 1364 (or higher), save your settings, and then try to connect to Xbox LIVE again on your console.
Nov 21, 2009 | Zhone (6218-I2-200) Router
Aaaaaaaahhhhh mtu xbox wont work getting fed up wot is problem
xbox live is down for maintainence it will be back up 2moro
Jun 16, 2009 | Microsoft Xbox 360 Console
Have the n+ wireless router/modem trying to connect via a cable to xbox live but keep gettin insufficient MTU even though the actual MTU of the router is higher than required
You may have to use trial and error to find the best MTU fit:
MTU Default of 1500 to 1492
Tart the setting the MTU @ 1400
MTU setting. Xbox LIVE requires a minimum MTU setting of 1364.
The information your console sends and receives is broken up into "packets" for transmission over your network. MTU is a setting that controls the size of these packets. If it's too small, you won't be able to connect to Xbox LIVE.
Top Solutions Try these solutions in order. If you give each one a shot and you still can't connect, contact Xbox Customer Support. Note that they will ask you try the suggestions on this page first.
Solution 1: Check your router MTU settings Xbox LIVE requires a minimum MTU setting of 1364. Usually, you can change your MTU setting from your router configuration web page, which is supplied by your router manufacturer.
Solution 2: Connect directly to the modem If your router's MTU is set correctly, try bypassing it by connecting your console directly to the modem. This will help determine whether there's a problem with your router or something else on your network.
Note
This may require you to move your console to a location close to your modem. This is a temporary arrangement, meant only to troubleshoot your connection. If your console is connected wirelessly, you'll need an Ethernet cable for this step.
To connect your console directly to your modem (wired connection):
  1. Find the Ethernet cable that runs between your console and the router.
  2. Unplug the cable from the router, leaving it connected to the console.
  3. Find the Ethernet cable that runs between the router and the modem.
  4. Unplug the cable from the modem, and plug the cable from your console in its place.
To connect your console directly to your modem (wireless connection):
  1. Unplug the USB connector for your adapter from the console. The adapter can remain attached to the console.
  2. Plug an Ethernet cable into the Ethernet port on the back of the console.
  3. Find the Ethernet cable that runs between your router and the modem.
Try to connect to Xbox LIVE again. If it works, there may be an issue with your router. Double-check the MTU setting in solution 1 above. Also confirm that you're using a compatible router, and make sure it has the latest updates from the manufacturer. If the problem persists, you may want to try a different router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 06, 2009 | Belkin N1 Vision Router
Have xbox 360 and it says my MTU settings are too low. How do i rise the settting.
This is a common problem if your XBOX is connected through a router or gateway. What you need to do is to change the MTU setting of your router. The minimum setting for MTU should be 1364. If you are not familiar with the configuration of your router, you can contact the technical support of the router's manufacturer. You can also search google.com for the step by step instruction in changing the MTU of your router - do a google search for your router's brand and model + MTU setup.
Good luck and have a nice day!
Oct 01, 2008 | Computers & Internet
Xbox live is not working it keeps coming up with 'you need an active connection to play online or system link matches' but my connection is fi and none of my friends can play as well?
Suggestion: <b>MTU Error</b>
Things to try:
Sep 30, 2008 | Video Game Consoles & Games
Mtu failure
Things to try:
MTU setting
Browse to the router's setup page, should be 192.168.1.1 or 192.168.1.0 and log into it. You just have to change the MTU. Put it to 1500.
Once logged in to the router, go to :
Setup
Basic Setup
Wireless Setup
Internet Connection Type
Connection Type = Static IP
Internet IP Address = 192.168.0.1
Subnet Mask = 255.255.255.0
Gateway = 192.168.0.1
Static DNS 1 = 192.168.0.1
Static DNS 2 = 192.168.0.1
Static DNS 3 = 192.168.0.1
STP = Enable
Optional Settings (required by some ISPs)
Router Name = client-mode
Host Name = 2WIRE383
Domain Name = [empty]
MTU = Auto
Please remember to rate all users who assist you for free :)
Sep 29, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
Siemens SpeedStream Modem (4100) (SS4100) Logo
3,143 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
