Question about Soleus KFS18GW 18,000 BTU Heat & Cool 230V Ductless Mini Split Air Conditioner with Electric Heat Ba...
Soleus KFGHP-09-ID Mini Split
When either on Auto Select mode or Cool, unit switches from AC to fan every 3-4 minutes( unit never turns completely off, it just goes AC on 3-4 minutes, fan 3-4 minutes and so on.....doesnt seem normal to me?
    Problem Solver:
  • 9 Answers
This is normal operation for these styles of minisplits. The thermostat is not in the remote but is located on the return air of the indoor coil, so the air needs to be flowing in order for the thermostat to measure the rooms temperature. Set your fan speed to auto and the fan will slow down when setpoint tempurature is met.
Phil Hodges,
Tech support Soleusair
Posted on Mar 12, 2009
Outside unit freezing up and not heating up room inside
Check the defrost board in the outdoor unit... it should have a wire coming off pins that are stamped 30, 60, or 90. If the wire is on 90, then try setting it to 60 or 30. This just enables the defrost board to check the freezestat in minutes...the shorter amount of time, the less likely the unit will freeze up.
Dec 16, 2013 | Soleus Ductless Mini Split 9000 A/c...
Hi there well it sounds like you got a R22 gas leak thats all
Dec 09, 2013 | Soleus Mini Split Air Conditioner
Goodman mini split model # wmh24-1a error code snowflake light stays on and 4th light from left blinks. i need to know what that means?
It's not an error. you have it set in auto mode and it is cooling. when it switches to heat the lights will switch as well. Set to cool only and it should go away.
Apr 28, 2011 | Soleus Mini Split Air Conditioner
My LG unit starts fine and cools but the fan runs at hi speed only and I cannot select any other speed although I hear a beep when they are seleted
In Auto mode, and jet cool or fast cool (if option is there in your remote), you can't change speed. Keep cool mode and then press fan again and again still you get required speed. Suppose, as you said beep sound is there when you select speed, check related speed terminal in PCB. If power is there, winding open in motor. If no power, replace/repair PCB. Thanks and hope it's helpful.
Jan 26, 2011 | LG LS-K1830CL Cool Mini Split Air...
Airconditioner LG LSk181-N2 shutting off
Sounds like your aircon is stuck on heating mode. Or. The outdoor fan speed is affected by ambient temperature, or low refrigerant. In heating mode the indoor fan will come on for a while to sense temperature and will then wait for the outdoor unit to pump up pressure and build up heat.
Feb 01, 2009 | LG LS-K1830CL Cool Mini Split Air...
Soleus KFS18GW 18,000 BTU Heat & Cool 230V Ductless Mini Split Air Conditioner with Electric Heat Ba... Logo
541 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Coss
Dennis Boxerman
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
