Question about Danby Portable Air Conditioner
Room temperature has not changed since hooking up new portable a/c
Hi, i just purchased a danby portable air conditioned DPC120068 and have had it operating for almost 3 hours now. when i turned it on, the room ambient temperature was 82 degrees F, i set the temp for 70 degrees F. After all this time the ambient temp has only fluctuated between 80-82 degrees and i dont know why it wont cool down the room. the mode is set on cool, the fan is on high. any suggestions?
Something I discovered with our portable air conditioner DPAC120068.
The temperature that you want can reset to the current temperature so when I turn on the conditioner I always press the down arrow button to see what temp it's at. Especially if it's been off for a while or on some other setting before hand, it's usually set at the current temp so I keep pressing "down" till I get the temp we want.
It's stupid that it should reset like that, but then again, that's danby.
Waiting 3 weeks for a replacement cord (as we accidently left the outside window closed and kept tripping the breaker...oops) and we still haven't got it.....
hope this helps
Posted on Jul 24, 2008
hope this helps
I bought mine last summer. Used it once or twice. Hooked up it today and it is a piece of ****. Been at 34celsius for the last 4 hours and still not even close to being cool .. and its in my bedroom
DON'T BUY DANBY portable a/c -----------
Posted on Jun 07, 2008
    Scholar:
  • 57 Answers
This may sound dumb but ( 1) Do you have the warm air from the unit to the exterior of the space? If the condenser is in the space your putting the heat your trying to remove right back into the space. ( 2 ) There should be an air supply and an air return in the space only. With that there should be a temperature difference of 16 to 20 degrees between the supply and return. ( 3 )A 1 ton unit usually will cool approximately 400 square feet. ( 4 ) It may take a while to pull the space temp down due to pulling the heat and moisture from the ceiling, walls, and floor. This could take 6 hours or more the first time you use the system in a space.
Posted on May 18, 2008
I need to purchase the remote control for Danby premiere dpac13009 Where I can find it ?
Ebay, only 1 available. $55 free shipping.
NEW Danby Premiere Room Air Conditioner Remote Control Transmitter A2529...
Appliance Parts Pros. $48 + shipping. I would call first because they don't have it in stock. Claim of 5-6 days may not be correct.
http://www.appliancepartspros.com/danby-dpac-remote-control-a2529-950-ap4556076.html
Repair Clinic $49 + shipping. Again call first because they don't have it in stock.
Remote Control A2529 950
Jul 27, 2016 | Danby Premiere 13,000 BTU Portable Air...
Danby 12,000 BTU Portable Air Conditioner - Doesn't Cool Enough
put a xtra fan on you to blow the cooler air around. this might help. but i think you will find it is to small to cool what your trying to cool. good luck and good day
saw
Jul 09, 2009 | Danby Portable Air Conditioner
The portable air conditioning unit turns to air conditioning mode to fan mode and back every 5 to 10 minutes. Is this normal?
Yes, Nicole it is. If the room is cooling down like it should. It actually is saving you money. As the compressor uses more energy than fan.
Hope this helps you.
Jul 14, 2011 | Danby DPAC13009 Air Conditioner
Hi, two days ago I bought a Danby Premiere DPAC13009 portable AC unit. It worked on the first day reducing the temperature from 32C in the room to 26C in a few hours. Although now there is no cold air...
Comperssors have a thermal overload. If there is a starting problem or low on freon the conpressor will shut down until cooled off. Try restarting and listen to compressor.
Sep 03, 2010 | Danby Heating & Cooling
What number fahranheit should i put my danby dpac 10061 temperature to get the room very cold
Celsius to Fahrenheit
(Celsius x 1.8) + 32 = Fahrenheit
Fahrenheit to Celsius
(Fahrenheit - 32) / 1.8 = Celsius
Hope this helps
Jun 02, 2010 | Danby Portable Air Conditioner
Danby ALSO does not cool 3 days old
Take it back where you bought it. A 12,000 BTU unit should be more than enough for a 192 square foot room, so there is some problem with the unit.
Jul 10, 2009 | Danby Portable Air Conditioner
Getting the room down to temp....
Danby Consumer help line: 800-263-2629 This is the best I can do for this product line having no information. From my knowledge and experience working with refrigeration and air conditioning there are a few things you should check. Check the voltage being supplied to the unit to insure it is with-in 10% of the name plate specifications. Check the air intake and exhaust hoses for good air flow and that the exhaust is not being recirculated into the intake. I suspect that your problem may be due to the compressor possibly overheating and tripping the internal overload protector. These take time to reset.
Jun 14, 2008 | Danby Portable Air Conditioner
Danby Portable Air Conditioner DPAC120068 - room temperature
Maybe, the compressor isn't starting? I'd take it back to where you purchased it.
May 18, 2008 | Danby Portable Air Conditioner
Danby dpac7008 portable air conditioner
I want to know how these portable air conditioners are supposed to be set up. Do they have to be on the same as the window out of which the hose goes? If the window is 4.5 feet off the ground, does the air conditioning unit need to be put on a table to make it and the window on the same level?
To the best of my knowledge the unit can stay on the floor and included the product features listed below and it does have a dehumidifier reservoir with direct drain and to make sure if you use the drain hose that the hose is higher than the item that you are draining the water into or you can elevate the unit so that the hose can drain outside and out the window - but you can also drain the water into a bucket or some thing that will hold water. I hope this will help you…..
Product Features
picexporterror From our expanded online assortment; not available in all Best Buy stores
picexporterror 7,000-BTU cooling capacity lets you cool rooms up to 250 sq. ft.
picexporterror Electronic temperature controls let you adjust the temperature in 1° increments for precision cooling; 3 fan speeds
picexporterror Dehumidifier mode removes up to 45 pints of moisture in up to 24 hours; 6.3-pint dehumidifier reservoir with direct drain
picexporterror Auto on and auto off timer
picexporterror Overload protection helps protect the air conditioner from power drains and surges
picexporterror Mesh filter is removable for quick and easy cleaning
picexporterror Includes remote
Apr 06, 2008 | Danby DPAC9030 Air Conditioner
Danby DPAC10061 portable air conditioner problem
you may have a factory defective unit that is not turning off the anti-frost heating coil (I have assumed yours contains this item based on your problem description). I would trade it in for a new unit, again assuming you have a warranty or the store offers a good in-store return policy. If this plan bombs, then open the unit and find the heating coil near the cool side of the radiator fins. then disconnect the power wires to the heater and prevent electrical short to wires with quality electrical tape.
Jul 06, 2007 | Danby DPAC8020 Air Conditioner
Danby Portable Air Conditioner Logo
666 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
