-   I too have a same problem on ELURA100. When i turn ON, i get a blue screen displaying CANON and freeze. It does'nt turn off even i turn the switch OFF unless i physically remove the battery. In play back mode, everything works fine. Canon workshop suggested to replace the lens kit costing 200$. I was almost thinking of dumping this camera until i saw this site...
I dont face this issue everytime, sometimes camera works fine....
I tried removing the outershell but not yet succeeded..fully...i will be trying out to look for the lens connector as suggested...-   BIs11111
May 20, 2008
-   Exact same thing happens to me. If I turn it on "Camera" mode the Canon logo comes up but will not go away. It will also not power down without removing the battery. In "Play" mode there are purple lines across the screen.
-   Guest
It took me a while to figure this one out but I finally did and mine is
back to working perfectly. The problem: The Play option worked fine but
the camera did not. When turned to camera mode the blue canon screen
would come up and then freeze. The only way to turn it off was to
remove the battery.
The fix: I was brave enough to take the
entire outer shell off the camera. On the main board, underneath the
screen/battery side, all the different parts are connected together.
There is a single connector from the lens that had come out of its
port. The ribbon connector must have somehow been shaken out of the
port at some point. With needle nose pliers I carefully fit the ribbon
connector back into the port. I carefully reattached the outer shell
and everything was back working!
I will warn you that this
task takes some time due to many many screws. It's a lot better than
sending it off for hundreds of dollars though.
First of all, English is not my natural language, so please forgive me. My canon elura 100, bought in the US 1 year ago, had the same problem. After a big fall (from a second floor), the camera landed in wet sand and after that the camera won't record again (it plays the recorded files just ok). Just today i had the time to check the camera, so i disassemble the camera and found a poorly connected cable, that goes from from the lens body to the motherboard of the camera. After reconnecting this cable the camera start recording again.
Canon Elura 100 problem: I'm getting a "Remove cassette" error however the part that is...
(More)
Canon Elura 100 problem: I'm getting a "Remove cassette" error however the part that is supposed to open allowing me to remove the cassette will not open. It sounds like it's trying to open but it never does. Please help!
My Elura 100 won't recharge when I plug it in (the recharging light does not flash), nor will it...
(More)
My Elura 100 won't recharge when I plug it in (the recharging light does not flash), nor will it start up. Any suggestions what I might try?
I have a canon elura 100. Haven't used it in a long time because I had to buy a replacement power...
(More)
I have a canon elura 100. Haven't used it in a long time because I had to buy a replacement power cord. I charged it the other day and when I turn the camera on, a large vertical white line appears on the LCD or in the viewfinder. There is no picture. I tried to reset by taking out back up battery and battery pack but still there when I turned the camera back on.
I just like everyone else am having the error message with the canon elura 100 to eject the tape......
(More)
I just like everyone else am having the error message with the canon elura 100 to eject the tape... but the part that is supposed to eject will not open. It makes the sound like it is opening but does absolutely nothing!
