Question about Canon Rebel XT / EOS 350D Digital Camera
Broken prongs where memory card seats.
The prongs in the memory slot that slide into the memory card are bent and/or broken. I need to find someone who can repair this ..
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey jarapo,
There are many repair centers you could bring your camera to. I would suggest either contacting Canon and finding an authorized service center in your area, or you could bring it to a Geek Squad® precinct in a Best Buy™ store and they could send it out for service. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 21, 2008
Fix read error sd card
Not sure you tried all the things I should do.
Be sure the cards are formatted, and try to format them in the camera.
But before you put in any card, check with a bright light close to the memory card slot, if all the contacts are clean and free, Just a little bit of dust or paper on one contact, could spoil all the fun. The contacts should be clem and shiny. All straight and to one side, Not one can be a little bent. If someone ever pressed a memory card in the camera the wrong way around, a lot of damage should be seen down there with some contacts bent or broken.
And be sure you did not switch all the cards to the lock position.
Jan 17, 2014 | Fuji FinePix S1000FD Digital Camera
Xsi rebel will not read or reformat memory card
You need to have a look at the slot where the memory card goes in. Using a light, look down in the slot at the pins the match up to the card. There may be one or more bent or broken. If the pins are damaged, then it would be a major repair. Usually once they have bent, trying to straighten them back causes them to break off.
Jan 16, 2010 | Cameras
Nikon coolpix s51 memory card write protected
SD cards have a slide switch along one edge. Slide it away from the contacts to protect, toward the contacts to unprotect. If that doesn't do it, try a different memory card. If that doesn't do it, then the detector inside the camera may be broken.
Jan 10, 2010 | Cameras
Broken cf prongs
Wow, CF cards. Well, as you said, the prongs broke which means you need it repaired. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=139&modelid=11154#SupportDetailAct
Advice: If you can, sell that and upgrade to the XTi or XT1 version of the Rebel. Now they use SD cards which doesn't have the prongs to break off. Also SD is more of the major memory card that is compatible with electronics. Otherwise, get a point and shoot. They are cheap and also use SD cards.
Repair cost:
2 Prongs replacement = All the prongs replacements. I'm not sure if they have that type in stock anymore. My guess is ranging from 60-100ish USD. Usually they will check to see what is the problem and bill you for their labor and parts.
Nov 16, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel Xti won't read ANY memory card. ''There is a problem with the CF card. Please replace the CF card.'' So i went out and bought a new one, the same message still appears! The prongs inside the...
It can be very difficult to see if the pins are bent, and harder to see if any have broken off. Do not probe with anything that can bend the pins. I suggest you create a small tool from a strip of paper and a toothpick. Pass the strip of paper over the pins while watching with a strong light. See if you can count each pin this way. A broken or missing pin will require repair by a Canon authorized facility. Your work will save you a diagnostic fee.
Oct 07, 2009 | Cameras
PS2 STATES THAT MEMORY CARD IS NOT IN SLOT, BUT IT IS.
THis is simple. Either your memory card has not enough room, the memory card is broken or the slot you are putting it in is broken. Try putting it in the other slot.
May 24, 2009 | THQ Video Game Consoles & Games
Can not insert memory card
If this phone is new, there may be a dummy card that is in the slot for protection. remove the dummy card before you insert a real card. If the phone is not new and you have inserted one before, there may be an obstruction blocking the slot or, the cooper prongs are bent.
Mar 16, 2009 | Samsung SGH-t639 Cellular Phone
Memory card won't go in due to wires bent up
The memory card is supposed to slide over top of those pins, they would need bent back down but I can not think of an easy way for you to do that yourself. If you have a service plan, now might be the time to use it.
Hope that helps...
Geno
Mar 29, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Not reading my memory card
You may have bent or broken contacts inside the card slot. It's tough to see, but if you look deep inside the slot, you may notice a contact bent or broken. If you're not able to see any damage inside, try taking a cotton swab with some alcohol (isopropyl, not rubbing or drinking type), and cleaning the contacts.
Mar 02, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon A75 Broken Prongs in Memory Card Resevoir
Yes, memory card pin set are available for replacement. Unfortunately, camera needs to be disassembled to some point to replace it. The average cost may run around $75- $125 in US repair shops.
Mar 16, 2007 | Canon PowerShot A75 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
199 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
