AKAI DLP PT50DL14, NO VISUAL OR AUDIO , SOME KIND OF GRINDING NOISE WHERE THE LAMP IS.. I HAVE TURNED IT OFF FOR 5 MINUTES AND STILL THE SAME PROBLEM
  • Frank Pisani Jun 05, 2008
    My Akai is rear projection and was made by samsung.
    I do not get a picture or sound. Only a red light comes on below the picture.
    Scholar:
  • 131 Answers
This is your color wheel bad it is a moving part please do not use you will damage it more. to fix this you will have to hire a tv repair shop. cost if only color wheel is around 450.00. and in some cases you have to replace the light engine which would be around 950.. to fix.
Thanks doctor video
Posted on May 18, 2008
PT50DL14 won't turn on,
You need to replace your color wheel.
Aug 21, 2012 | Akai Televison & Video
When the tv is turned on I hear a loud grinding like noise
May I know if the unit won't power up, has a three blinking led light at the front panel? Also, please check if the grinding noise is near the lamp assembly.
Mjsazon
Dec 01, 2011 | Samsung DLP HL-P5663W 56" TV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Akai DLP projection TV. Picture is fine except lamp is not illuminating a 3-4in area on the left side of the screen. You can see the picture over there but it is dimly lit. I can't seem to find a way to...
The problem is the light tunnel is collapsing. This is a VERY common issue with the Samsung/Akai DLP TV's. It is four mirrors used to transfer the light after it passes the color wheel to the DMD board. When part of it collapses the grey bar that you are seeing is the end result. This is a part that usually requires a technician to replace as there is a little tear down of the light engine itself and you would be handling delicate parts. The part number for the tunnel assembly is BP96-01961A and I have included a link so you can purchase it through the Samsung website. Please take a few moments to rate my answer. Thanks..
http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP96-01961A&search%5Fmodel=PT50DL14
Nov 20, 2009 | Televison & Video
Replaced lamp and still no pic lamp light comes on then lamp light goes out PT50DL14
This Akai TV is actually built by Samsung. You need to count the blinking lights on the front panel.This indicates an error code.With the code I can tell you what circuit has failed in the TV.
Jul 30, 2009 | Televison & Video
Optical engine for akai pt50dl14
Here's a link to order the original Akai light/optical engine for this model (PT50DL14) from a major parts distributor:
Akai Samsung PT50DL14 Replacement Part Light Engine / Optical Engine Block
Feb 17, 2009 | Televison & Video
Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Apr 10, 2008 | Akai PT5598HD 55" Rear Projection...
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Televison & Video Logo
179 people viewed this question
Top Televison & Video Experts
Electro Med Services...
