Question about DeLonghi CF210 Portable Air Conditioner
Is this thing working?
It won't cool below 90. It's worse than a fan. The air is not cool and I can't find the manual. I think I did not install it correctly. Do I have to put ice in that tray? Because that tray is empty. Even after using it for 3 days. I recently found this tube with water in it. I released it and still nothing. The air coming out is hot not cool or cold. Please email hibiscus246@gmail.com
I had the same problem...I was going to get rid of the unit...I notice that tha red light on the little screen on the top was on...then I closed the tray (all this time I though it was closed) all the way and the red light went off and the unit started cooling! I hope this may help you.
Posted on Jul 31, 2008
The radiator fan on my 2007 bmw 525i works fine while car is driving. Once i stop at a red light or in traffic the the fan stops working, ac blows hot air and mins later the car overheats. The car has a...
My guess is that your electric fan is NOT operating at all. Under normal conditions, just going down the highway, your cooling system will function just fine without a fan running. The air flow through the radiator is adequate to keep things cool. However, when you stop, you quickly get into an "overheat" situation. Actually, you should be able to hear your fan begin operating when your engine temperature starts climbing or your air conditioner requires the fan to do its thing. Note: If you've ever severely overheated your engine, your problems may be worse than just a fan not running, but you really do need to confirm whether your fan is operating correctly, or not. Another note: I had a vehicle with a tendency to overheat when stopped. It turned out to be a faulty (leaking) pressure cap on the cooling system.
Nov 04, 2013 | BMW 525 Cars & Trucks
Car won't start after starting it with coolant temp sensor disconnected
Try a boost first before taking things apart,sound like low voltage.
Now about the fans.Sometimes it's easier (if the fans will work with voltage applied) just to install a relay and fire it off the switched power wire at the A/C compressor.Use this relay supply to voltage to the fans when the compressor runs.Want fans when not using A/C?Run a "in rad hose" temp switch and run that wire to the same relay to run fans when temp rises.Think after market hot rod stuff and keep it easy and simple,
Apr 10, 2017 | Cars & Trucks
My Goodman unit won't cool below 78 degrees inside during this heatwave. The thermostat says
your home may not be insulated well enough or you could have leaking duct or your system may not be charged correctly ac systems are not sized to cool below 76 degrees above 90 degrees outdoors because this will increase your utility bills during the cooler temperatures. thank your governement and all the regulations we have to follow for this. they would rather you save money than be comfortable. and we are actually in violation of state law and federal law if we install a unit that will cool below 76 degrees on 90 degree outdoor temp
Jul 02, 2012 | Goodman CKL36AR36 Air Conditioner
I have an acer 5741G which my father got me last year. i have just installed one game in it. when i play the laptop gets heated too much(that too within 30 minutes) and i have to stop playing to cool it...
Overheating of a laptop can cause degredation of components and possibly system failure but generally it could be a very simple fix. Best thing to do is to go out and buy a laptop cooling stand for it. The laptop will sit on this stand, which has fans that will blow cool air into the laptop from it's intake below the laptop and this should help to keep it from reaching critical temperatures. I recommend a laptop cooling stand for anyone who owns a laptop as the one fault of almost all laptops is the intake is usually directly below the laptop, and when you rest it on your lap you end up choking out it's air supply allowing it to overheat.
Jul 20, 2011 | Acer Aspire One PC Notebook
I RECENTLY INSTALLED 3 LG INVERTER MINI-SPLITS.TWO 12,000'S AND ONE 24000 BTU.THE 12'S SEEM TO WORK GREAT THROWING NEARLY 140' HEAT. THE 24 IS LUCKY TO THROW 90' HEAT AND I DON'T SEEM TO BE ABLE TO CHANGE...
I think you keep in Auto mode. If in Auto mode, you can't change fan speed. Keep in cool/heat mode and then press fan button in remote to select desired speed.
Dec 16, 2010 | LG Heating & Cooling
My radiator fan is not working. the radiato fan relay and the relay for radiator fan (speed 1) are not in the car. do i need to put them in for it to work or what other problems could it be?
I think you are talking about the radiator fan for the coolant in first place and than about the heater fan (speed 1)? If yes than first thing is to get the relay in for the radiator fan as it will not cool your coolant liquid and will cause the engine to overheat, with the second one it is a faulty resistor inside the vent and that is why you don't have the first speed, unless the pollen filter is dirty and the first gear cannot actually **** enough air.
Nov 18, 2010 | 1994 Audi 90
Rooftop RV Air Conditioner: temp outside 90 or above. compressor kicks off ....
It sounds like maybe an overload for the compressor is tripping and resetting once the compressor cools. Possibly due to a low charge.
May 03, 2010 | Heating & Cooling
2007 altima that air condition won`t turn on at times .
sounds like a overheating relay. when it gets hot the air doesn't work. and when you shut off the car it cools and works again. the relay is located near the fuse panel
Aug 04, 2009 | 2001 Nissan Altima
When we turn the AC on, after a couple of minutes we hear a hum which lasts about a 1.5 minutes then shuts off. No fan air movement or cooling detected. The unit is 5 years old. We RARELY use it and when...
Go up on roof and using a stick or similar, poke it through the air holes in side & try to turn the fan blade at rear of the air conditioner. Make sure it's off at the time. Try to get 2 or 3 complete revolutions of the fan blades, then try turning it on fan only first,and let it run on fan for a few minutes, then switch to cool. If worse comes to worse and you can't get blades to turn, remove cover on roof (watch for wasps & bees) and spin fan blades a few times by hand, step back & have someone try fan only. If that works, then try cool. Sometimes they get a dead spot from sitting, and that will get it going again, 90% of the time. Let me know how it goes.
Jul 27, 2009 | Dometic Rooftop RV Air Conditioner
Won't cool below 80degrees f
If you have had this unit for a while may need to geet the refrigerant checked
Jul 30, 2007 | DeLonghi CF210 Portable Air Conditioner
DeLonghi CF210 Portable Air Conditioner Logo
410 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
