Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
Stopped working.. Blown? or..
I have a 15" L7 Kicker and and 1000RMS PDX Alpine amplifier... i had it all hooked up and it sounded fine..it was only running for about two hours and it just stopped working. I noticed my amp was off and and all 4 fuses were blown. I replaced the fuses and the sub barely playedand souded almost blown but i dont know how thiscould be seeing as in a barely played it and i didnt turn it up loud at all and now it wont make a sound at al.. I checked to see if power was goig through and power reaches all the way to the sub. When i touch the power indicator to anywhere on the sub it makes a weird sound but this is the only time it will make any sort of sound at all..
    Scholar:
  • 173 Answers
How did u wire the speaker ?what is the speaker rated at 2 ohm or 4ohm? thees kicker l7s 15 inch is rated for 1000 rms and 2000 peak the only thing that could of hapend was somthing was touching some were in the wiring or u hade the speaker wired at a load of 1 ohm
Posted on Sep 14, 2008
How do you bridge an Alpine PDX amp
you have 2 + and 2- right? twine both speaker wires together. like + to + and - to - and then pick only 1+ and 1- to hook up and then you should double the power to the speakers only
Mar 20, 2010 | Alpine PDX-4.100 Car Audio Amplifier
PDX 1.1000 amp overheating?
Hello thefatman69e,
The Alpine PDX-1.1000 is a physically small amp to produce the power that it does. The result is that it has less physical area for heat to dissipate. Running at or near it's maximum output into a 2 ohm load, it needs some serious airflow to keep it cooled down. I'd look for some way to get more air to it.
Hope this helps.
Sep 21, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Alpine pdx 1.600keeps cutting out
you need more batt, more amps, try new batt, capacitors are paperweights, spend on good batt.
May 14, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Alpine PDX 1.1000 low power output - sub not loud
system not configurate properly go to a pro and let them do for you you have good equipment just need to put together rite.for wht you have you can get better sound than that,,good luck
Mar 30, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
I had 3 subs hooked up to my pdx 1 1000 and it stopped playing one day and hasnt played since
1. check your B+ wire and make sure the fuse is good, and your ground wire and are you certain that the remote turn on is good?
2. If you have 3 subs runninng on the amp i hope those subs are 8ohms and you wired them in parelell to give an impedance of 2ohms. Let me know. Mark @ Sounds Good to Me.. tempe, az
Mar 18, 2009 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
I have a Kicker 08S15L72 15 dual 2-ohm need it wired for 4 ohm
ok im going to try to explain this you have 2 voice coils , i will refer to as vc1 and vc2, you take vc1 positive and connect to vc2 neg then use vc1 neg and vc2 pos to the amp according to pos and neg signs.
Feb 22, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Channel 2 crackles
Make sure your speaker wiring does not come close to the 12v power cable running for your amplifier. If your amplifier's 12v power cable runs on the drivers side of the vehicle, run your speaker cables on the passengers side and make sure your tweeters have a high pass filter to stop any pickup of engine sound (When you are driving you *WILL* notice it at high RPM. a HPF (High Pass Filter) will also stop those nasty hissing sounds on S's.
Feb 11, 2009 | Alpine PDX-4.100 Car Audio Amplifier
Blown subs
Generally, when woofers freeze, the coils weld themselves to the magnet structure. It wouldn't be possible to repair them without the required replacement parts. Even if you could get the replacement cone/voice coil, the magnetic gap and the area around it isn't likely to be in good enough condition to accept the new parts. With only a few exceptions (Digital Designs and other high-end woofers), woofers are disposable if they're not under warranty.
Aug 01, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Kicker zx750.1& two 15"kicker solo L7 2ohm
if the amp could handle 1ohm paralell would work if not they wire in series
Apr 08, 2007 | Kicker (ZX750.1) Car Audio Amplifier
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
226 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
