Question about Gaggia Syncrony Espresso Machine
Gaggia Syncrony Compact
The green LED 26 is flashing to descale. I turn on the stamer knob however the water only runs for a short period of time. the LED keeps flashing and I cannot make perform any other function.
If I turn off the machine off and turn back on 23 and 24 LED flash once and then LED 26 flashes.
I need to make a coffee!!!!!!!!!
  • 515 Answers
If you are in decalcify circle you have to finish it before the machine goes to ready again.
When you decalcify the machine, there will comes water for a short period, then it hold up for a couple of minutes then it will run out little more water. So will the machine do to the water tank is emty.
Posted on Jul 11, 2008
When I turn on the coffee machine flashing red button calcing. and 'put in a container for water descaling solution., when I hold the button for more than 5 seconds nothing happens.
push it for 5 second and if its still flashing doesn't matter turn the steam knob anti-clockwise end let the machine do to the descaling cyrcle, when then water tank emptied the rest of buttons starts to flashing, turn the knob off and your machine is ready!!
Jan 12, 2014 | Gaggia Syncrony Compact Coffee...
I have a Gaggia Syncrony Compact machine which I am trying to descale. I have added the descaler to the water in the tank. when you hold down the button (26) more than 5 seconds nothing happens.What is the...
To descale the appliance proceed as follows:
• Mix the descaler with water as specified on
the package and fill the water tank.
• Switch ON the appliance with the ON/OFF
switch (7).
• Press the button (26) for at least 5 seconds to
select the descaling operating mode; the LED
emits a fixed light.
I noticed you did not mention the switch ON before you pushed button 26. Try that should work.
Gaggia Syncrony Compact.No coffee comes out. Coffee grinds then the 3 big clicks, then nothing comes out - grounds get dumped. Bought a new brew group, but same problem.Looked at the book and tried to...
Your machine have scale deposits in a very hard form that is why the water can not run freely.
Here in this link you try descale
http://www.fixya.com/support/r4335301-descaling_espresso_machines_never_use
Try it for 3-4 days repeated, if you dont have any results then you need to desmndle the machine and manualy descale it.
Sep 24, 2010 | Gaggia Syncrony Compact Coffee...
I can not get out of descaling mode. I turn it of, unplug it, went into programing mode. Is there a way to reset it? Thanks
If you are talking about the descale light, you must let the machine quit on its own. The pump has to stop on its own. Any interruption (you stopping the machine) will keep it in the descale mode. Once it stops on its own, the lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle (putting water in the tank and closing and then reopening the steam knob)until all the red lights go away and you only have a green blinking light. Now your finished descaling a compact without a digital display.
Jul 17, 2010 | Gaggia Syncrony Compact Coffee...
The led 27 flashing no stop
Hi
Jan 06, 2010 | Gaggia Syncrony Compact Digital Espresso...
Descaled and got 23, 24, and 27 buttons flashing
Fill water tank and open the knob to empty boiler and circuit.
Nov 29, 2009 | Gaggia Syncrony Compact Coffee...
Brand new Gaggia Syncrony Compact will not pump water. Red light no. 27 flashes, and machine makes sounds as if trying to pump.
Open the hot water valve, if it flows for a second and stops, then pusi in on the knob if that works, call up support and ask for a new stainless steel valve for your machine.
Aug 01, 2009 | Gaggia Syncrony Compact Coffee...
Problems Descaling
Hi You have finished the first part of the descale process if that machine is like all the others. Rinse out your water tank and put fresh water in it. Then put it back on the machine and close then open the knob for steam and let it run the whole tank out. When it is finished the descale light will disappear and your green light will blink and the water light will be steady. Refill the water tank and close and then open the steam knob to prime so the water light will go out.
Jun 12, 2009 | Gaggia Syncrony Compact Coffee...
Descaling
(Button 26 is the right-most one (2 intersecting
ovals.)
From the Manual:
• Direct the steam nozzle (14) toward the drip
tray.
• Position a vessel of adequate capacity under
the steam nozzle and turn the hot water knob
anticlockwise (16). The appliance starts an
automatic descaling cycle with pauses preset
by the manufacturer and managed
automatically by the appliance.
• At the end of the cycle, the flow of the
descaling solution is shut off and the 5 buttons
start flashing simultaneously.
• Turn the knob of the hot water nozzle (16)
clockwise to OFF. In this case, also the warning
light (27) flashes.
• Rinse the water tank and fill it with fresh
drinking water.
the steam nozzle and empty 2/3 of the
contents of the water tank by turning the steam
knob (16) anticlockwise; to shut off the flow,
turn the knob (16) clockwise.
• Let the appliance heat up and empty the
remaining contents of the water tank by turning
the steam knob (16) anticlockwise; to stop the
flow, turn it clockwise.
HTH
dave
Aug 14, 2008 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony Espresso Machine Logo
170 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
