Question about Lexmark Z735 InkJet Printer
Computer having problems communication with printer/scanner
I am having trouble with printer, a blue light is blinking and when I try to print there is no communication to printer from the computer
Posted on Oct 13, 2008
4 Suggested Answers
myob247
  • 1342 Answers
SOURCE: All in One Scanner/Printer problems
Click HERE for Vista drivers
Posted on May 12, 2008
old marine
  • 1815 Answers
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
Posted on May 21, 2008
Tirzo
  • 94 Answers
SOURCE: my scanner doesn't communicate with my computer but my printer does
Hi, there are many possibilities why your scanner is undetected by your computer. It can be its logical connection, scanner driver or the scanner itself.
If you have Windows operating system, please check Device Manager. In the Device Manager please check for the following:
1. Any yellow or red X's, question marks or exclamation marks related to the scanner.
2. Under the Category of Imaging Devices - Check for Epson Product name.
If IMAGING DEVICES is listed, test the scanner from PAINT as follows.
If IMAGING DEVICES is not listed then the scanner is not being recognized. Try another USB port or cable until the scanner shows up in the Device Manager. (The scanner must be on and connected in order for the computer to recognize it)
If you see an Imaging Device that points to your Epson Scanner or Unknown Device that has a yellow question mark or exclamation point, you need to update the driver.
Try to scan in Paint to isolate the issue between your computer and scanner.
To scan in Paint, do the following:
1. Click on START > ALL PROGRAMS > ACCESSORIES > PAINT.
2. Click on FILE then select FROM SCANNER OR CAMERA.
3. Choose COLOR PICTURE.
4. Scan.
If it does not work, it is possible your Windows Image Acquisition (WIA) service is not started.
To restart this process please follow the steps listed bellow.
1. Click on Start > Control Panel > Administrative tools
2. Double-click on Services to access the list of available services.
3. In the Services window scroll down to the bottom and double-click on the Windows Image Acquisition (WIA) Service.
4. Select the STOP option.
5. Click the START option to restore the service.
6. Try scanning again into Paint.
If it scans fine, try scanning from the application that you normally use. If you are still unable to scan or receive any error messages, try reinstalling the scanner driver or software.
If you have Macintosh operating system, please check Apple System Profiler if your scanner is properly detected. The reinstall the scanner driver.
If your scanner is still undetected, please contact your scanner manufacturer for any possible driver updates.
Posted on Nov 14, 2011
On scanner the x is light up and printer will not scan . What is my problem?
Make sure the scanner usb and power leads are securely seated the drivers for the scanner might have been corrupted you might have to uninstall the scanner restart your computer then reinstall your scanner If your printer/scanner came with an installation disc the drivers could be on it you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow Question/exclamation ? ! mark or a red X this will mean you need to install a new driver for this device right click to update driver select properties again you will have the similiar options also have option to troubleshoot
Mar 13, 2013 | Office Equipment & Supplies
Tip
I get error 'Unable to find destination PC-Check the PC' on Kyocera Mita
Hi.
This error means that there is a communication problem between the printer and the computer that is receiving scanned file. The error is usually prompted on network installed printers.
Check to ensure that the Scanner File Utility software is running and the computer is able to receive data.
Try restarting the computer and printer. Disconnect both units from power supply for five minutes before restarting.
Check if you have firewall or security software active on computer that can block communication from scanner. Ensure that the scanner utility is listedas an exception on firewall settings, if the application is not present, then you need to add it to allowed applications list.
Ensure that you have granted Scanner Utility access to system resources if asked.
Reinstall printer software and driver on PC. This can be done either using the disk provided with the printer, or using the download from Mita website.
Test the computer network cable. If cable is worn it can cause communication errors. This problem is usually occurring on LAN (network) printer installation. If using local installation via USB, then test using a different USB cable. If USB cable is damaged or too long (over 10 m.) , then you may get the error stated on local installation.
The most common reason for this problem is firewall settings or network problems. Network problems may be difficult to troubleshoot. Remember also that there is a built in firewall in the router resident software. If the router is set to block inbound communication from printer to computer, or if printer and computer are in two different IP ranges (eg. 192.168.1.xxx and 192.168.2.xxx), then you may get communication between computer and printer blocked by router firewall.
Here a setup manual (click to download), also ensure that you have performed scanner setup correctly.
Here also Kyocera Mita download driver page:Kyocera's managed print services .
Regards.
on Mar 31, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
Card does not appear to be communicating with a KodaK i840 scanner. How do I trouble shoot this?
the drivers for the?scanner might have been corrupted
if your printer/scanner came with an installation disc the drivers could be on it
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port?and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also have option to troubleshoot hope this helps
May 18, 2011 | Kofax Adrenaline 1700s (EH-1700-1000)...
I haven't used my scanner for some time and now it won't work. A message says can't communicate with scanner, check scanner, may be not connected. we took it with us this winter but have checked all the...
Hello.
Either the driver is corrupted or the scanner component is faulty.
Reinstall the driver for your device. If still a problem and the other functions work, but not the scanner, the scanner part is faulty.
Hope this helps.
Apr 10, 2010 | Canon PIXMA MX310 All-In-One Printer
The software cannot communicate with the scanner (Prime Film 3600
I have a PrimeFilm 1800u. When I attempt to scan into a Roxio application, the program does not respond. The hardware and software are both installed. No problems scanning or communicating with this scanner before. Is there somethere there that has a soultionfor this problem ? Thanks
Mar 16, 2009 | Pacific Image PrimeFilm 3600u Film Scanner
May 20, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Scanner connection to the PC
i solved mine by replacing the usb cable with one that is 2.00 high speed and inti noise shelded benton-r
Nov 04, 2007 | Canon PIXMA MP160 All-In-One InkJet...
SCANNER ERROR
Generally all in one devices have problem with drivers!!! The main problem is communication between computer and printer!! Try to find another driver or reinstall the old ones!!!
Sep 24, 2007 | Xerox WorkCentre XD100 All-In-One Laser...
Lexmark Z735 InkJet Printer Logo
232 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
