FixYa.com
Tags:
Nikon COOLPIX L3 Digital Camera
Memory card error (by 3 users)
posted by A-Fed on May 18, 2008
My camera (Nikon Coolpix L3) turns on then shows me 'this card cannot be used'. I've been using this card for 2 years and I think the problem started when i was transferring pictures onto the computer. It transferred about two-thirds of the way then stopped and the message appeared. What should i do?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by mel19, posted on Jul 23, 2008
memory card is write protected
Comment by Guest, posted on Jun 28, 2008
When the memory card is instered and the camera is turned on it shows "This card cannot be used".
Best Solution
posted on Jun 21, 2008
FixYa! (100)
dlundmark
Rank:Wiz Wiz
Rating: 79%, 24 votes
Try another card. The card can have a life limit, after all it is flash memory.
Also try to use the card in a card reader, not the camera. If that works, and you can save your pics... (remember never try to delete or change any of the pics. on the card from the computer, a lot better chance of corrupting the files...that may be due to the fact that the camera and the computer can be seeing different ways of making folders and reading them...just mention that because I had it happen... always format and delete all pics in only the camera you use that card in.)
If you are successful to transfer your pictures, then format the card in the camera, and see if it will work.
The final on this is that if the card will not format, and will not save pictures, then it is finished. You can try to use it in another kind of camera, sometimes that may work as well.
Rating Locked! (?) A-Fed has rated this solution as FixYa!
Can you Help with these Digital Cameras problems?
Nikon L3 Lens wont extend
Started today- worked fine this... Answer This...
problem with dealer
i had bought a nikon coolpix L3... Answer This...
Deleting photos
Can find no assistance in the... Answer This...
nikon L3 lens stuck
my little nephew was playing... Answer This...
Nikon Coolpix L4
1. Camera had fatal lens error... Answer This...
Repair Service
Find Digital Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
