Question about Electrolux Refrigerators
Electrolux icon refrigerator error code c err
What does the error code SY EF mean on an Electrolux French door refrigerator?
Hello Suzanne, thank you for your post!
I understand that your Electrolux refrigerator is displaying an error code of "SY EF". An "SY EF" code stands for an evaporator fan circuit failure. This could also be a miscommunication with your refrigerator and I would advise performing a reset on your refrigerator. You can reset it by disconnecting the power plug from the outlet for roughly ten minutes. If that does not help correct your issue you may need to replace your main control board or a wiring harness. For proper disassembly and repair of your refrigerator I would recommend having a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Mar 23, 2015 | Electrolux Refrigerators
Electrolux induction range err code co55
Thank you for your inquiry, Phillip!
From what you have described your Electrolux range is displaying an error code of "co55". I was unable to locate that specific error code. It might be a display error with your range and I would suggest performing a reset. You can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not help correct your issue could you please provide me with your model number? With that information I would be able to assist you further. -Matt
Feb 25, 2015 | Electrolux Kitchen Ranges
My Electrolux time manager washing machine wont start jus flashes red with Err
Hey Beverley, thanks for your post!
I see that your Electrolux washer is displaying the error code "ERR". Typically a number follows the "ERR" but if no number followed the "ERR" error code then your washer has detected an error. I would perform a reset on your washer which can be done by unplugging the power cord or flipping the household circuit breaker for roughly ten minutes.
If that does not help correct the issue it could be a problem with your control panel or wiring harness. I would recommend seeking out assistance from a professional in order to properly diagnosis and repair your washer. I hope this is helpful to some degree. -Matt
Oct 04, 2014 | Washing Machines
How to fix error code 0.00
Hello friend, thanks for your post!
Based off the information you provided your Electrolux washer is displaying "0.00". Typically any error code that is labeled "00" means no error code stored, which means it's a false error code. I would recommend performing a reset on your washer due erase any false error codes. You can do that by disconnecting the power from your appliance, by either unplugging it or flipping the household circuit breaker, for ten minutes.
If this step does not help resolve the problem please provide me with the new error code or if your display continues to show "0.00" I would suggest seeking assistance from a professional to come out and properly diagnosis your washer. I hope this information is helpful. -Matt
Oct 02, 2014 | Electrolux Washing Machines
Error code e5
Hi friend, I appreciate your post!
I understand that your Electrolux refrigerator is showing an "E5" error code and not cooling. "E5" typically stands for Showroom mode, you can press and hold the "Up" and "Down" keys simultaneously and that should restart your refrigerator back to normal operation. Could you reply back if that corrected the issue? Thank you. -Matt
Jul 27, 2014 | Electrolux Refrigerators
Electrolux icon side by side fridge is flashing E and F instead of holding the temp for the freezer and fridge. How can I fix this?
Hello Debbie Zymet - Typically error code E and F indicates that there is an error with the evaporator fan in the refrigerator compartment and fan in freezer. I would suggest contacting a professional move forward accurately for proper diagnosing and repair.
Nov 18, 2012 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Electrolux refrig is showing code CO what is that?
Hello bannanderson - Are you certain the error code is CO? This manufacturer does not have any CO error codes for any refrigerator or other units. Could you please try resetting the unit by unplugging it or flipping the household circuit breaker off? Wait approximately ten minutes and if the unit is experiencing a generic communication error, it should be follow by another error code. If it proves to be ineffective, contact a professional to move forward accurately.
Nov 12, 2012 | Electrolux EI26SS55GS Stainless Steel ...
FREEZER PROBLEMS ELECTROLUX ICON MODEL E32AR75FPS2 READS AN E ON THE FREEZER CONTROL HAS LIGHTS BUT NO COMPRESSOR OR FANS
Hi - Typically error code E on Electrolux freezer indicates an error with thermistor. Since the compressor does not kick on, I suggest contacting a professional to move forward accurately and properly diagnose freezer.
Oct 16, 2012 | Refrigerators
The electrolux refrigerator icon counter depth.
According to Electrolux customer service center, the E..... F error message refers to the evaporative fan that has malfunctioned.
When ours went out the fan made a loud buzzing sound like the fan bearing went bad
Jun 28, 2009 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Mar 07, 2008 | Electrolux EW1200i Front Load Washer /...
Refrigerators Logo
324 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
