Question about Toshiba 50H81 50" Rear Projection Television
Toshiba color issues as posted
My problem is with the red, what is this code you are talking about?
    Genius:
  • 1,030 Answers
Please re ask your question....not sure what code your talking about
Posted on May 20, 2008
How do i know the color codes
Color codes for wiring vary between manufacturer. Other than red/black for power, it would be very hard to provide any more information without knowing the make and model number of the item you are talking about.
Sep 07, 2014 | Radio Communications
Getting error sc 479627 toshiba e studio 3511
479627 is your meter not the error code.
3511 and 4511 color machines will be obsolete at the end of this month. Advise you call your local Toshiba dealer and talk to them about a trade in upgrade.
Jan 13, 2013 | Toshiba E-Studio 3511 Color Copier
WD-60638 DLP TV does not have any red
It would have come with a 1 year labor and parts warranty--now is the time to see to the issue---Talk to Mitsubishi if you do not have a extended warranty that is active.
Nov 03, 2012 | Mitsubishi Televison & Video
When I first turn on the Toshiba projection tv the color has a strong red hue to it which clears up gradually
I would suggest when turning set on cold---turn color all the way off and examine screen as set warms up---if red to some degree but gradually becomes black and white the issue is either a "touchy" red screen control on the screen/focus block or a problem on the circuit board plugged to the bottom of the red tube.
I guess the real question is how long until it is normal?
May 20, 2012 | Toshiba Televison & Video
My toshiba TP50H15 color tv comes on then off and the light blink
The flashing power light on those Toshibas is usually caused by capacitors on the power board having failed solder connections. I have fixed them before by removing the power board and resoldering the capacitors. If you have experience with soldering and electronics it is an easy repair. Most shops will recommend replacing the entire board since their labor to repair it would probably cost more. Toshiba put out a service bulletin on this issue which a good technician should be aware of. (If memory serves the capacitors are C109 and C110.  Since your TV still turns on you probably haven't blown fuse F860 which often blows when these capacitors act up.)
If you would like further help with this please post a comment back here.
Dec 05, 2009 | Toshiba TP50H50 50" Rear Projection...
CAN NOT CONVERGE THE RED COLOR UP AND DOWN
this indicates to me that one of the convergence convergence output resistor has open. there is a slight chance that the convergence ic amplfer is at fault. but the fact you can go left and right and not up and down makes me feel its the resistor. IM sorry thats techy talk. do you have any electronic traning. let me know make and model and ill try to get the component number and value for you
Nov 22, 2008 | Toshiba Televison & Video
My 50 inch 5 year old Toshiba TV has a wavy screen with the colors stacked instead of on top of each other and the red convergence cross hairs are crooked
you need new convergence ICs. post your model number and I will post the correct IC numbers for your model and a link where you can get them with free instalation instructions.
May 29, 2008 | Toshiba Televison & Video
Display problem
hi. its the lcd problem, the ink leak causes this issue..
Jan 02, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba 50H81 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
