Question about Toshiba Televison & Video
Toshiba theatre view tv. No picture. Appears as if t.v. is off but power light keeps blinking. Will not turn on with either the remote or power button on t.v.
    Genius:
  • 2,035 Answers
If you unplug the tv from ac. Let it sit for 10 minutes. Plug it back in and check if its on.
or
ONE: Do a hard reset. Merely unplug the power cord for 4 hours or more. This will clear any software corruptions that might have accumulated.
TWO: When you turn the set on listen very carefully for a sizzle or crackling sound down in the lower back side of the set. This is the high voltage coming up. If you donot hear it the high voltage generator is faulty. If you do hear it and still a blank picture you have video processing troubles. Either way it is not a home remedy and you will need a service tech to diagnose the set with instrumentation.
Posted on May 18, 2008
  • 2,326 Answers
The problem could be in the convergence amps. stk's., common failure on Toshiba TVs.
The power board which has the power transformer has a set of wires that go to the convergence circuit. If you disconnect this cable the unit will power up. Of course the convergence is all messed up because its missing its voltages, 30 18 18 give or take.
Let me know if you need further assistance.
    Genius:
  • 3,422 Answers
You will have to get it serviced and thats the only solution.It is a power supply issue.It is gone into protection mode to further avoid any damage.
Goodluck..
    President:
  • 2,712 Answers
Hello im2ntens,
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try plugging in the TV through the USB on its panel to a computer or USB charger, and it may work. However, this is only a temporary solution.
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off. Since it is LCD, it doesn't take much power...only a few bucks extra a month for your utility bill.
4. A circuit board may crack about some of the larger components mounted on it. You can inspect the PCB's for fractures, and then repair them. It may also be poor soldering that has failed. I would be checking for these things first.
5. If you want to go in for a long term solution, you can easily replace the whole power board or just change the faulty capacitors. You will have to open the back panel and take a look. You can make out which are faulty, because their caps will be swollen on top. Here's a sample pic of a bust capacitor (not same model):
Check the specifications of the faulty capacitors, and get the replacements from your local electronics shop. If you are comfortable with this, you can use a pair of needle nose pliers to G-E-N-T-L-Y pull out the defunct capacitors. Once that is done, solder in the new capacitors carefully. If are unsure how to do this, try to get a friend who knows how to do this kinda stuff do it for you, or get a qualified technician. Warning: If you do not have a background in electronics repair, or are inexperienced, get a qualified technician to do it for you.
REMEMBER there are very dangerous voltages inside a TV that can KILL. Be sure to work SAFE when dealing with electricity. DISCONNECT THE POWER BEFORE YOU DO ANYTHING.
Hope that helps!
Don't forget to "Accept" this solution if you find that it helped you :)
Thank you for using FIXYA!
IrishDruid
Tv turns on and off 3 times before picture appears
Ballast Board its what turns Lamp on Call Encompass or visit their website. 1-800-638-3328
Dec 14, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Toshiba 51 inch theatre view Blinking red light -- no sign of picture or sound
Had the same problem on my 42in. and it ended up being 2 of the fuses and 1 board had to be replaced.About 900dallars worth of work,it was covered under warr.
Nov 29, 2009 | Toshiba 53H71 53 in. Rear Projection...
I have a toshiba hd theare view tv. The other day
Hi
did you notice the standby light? or blinking lights? and how many blinks as you see?
Thanks!
Jul 08, 2009 | Toshiba 55H70 55" Rear Projection...
The tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
May 27, 2009 | Toshiba 57H81 57" Rear Projection...
Power problems problem on
I would try a power drain:  Unplug the TV's power cable so the TV is not grounded to the house.  Then press and hold in the TV's own power button for one minute to drain the capacitors. Plug the TV back in and see what happens.  If the TV will still not turn on, I would say you have a problem with the TV's mainboard as a dead power supply will not light any LED's for you.
Mar 24, 2009 | Toshiba CN36X81 TV
Turned the big screen toshiba theatre view on, worked good for about 2 min. Then just shut down, not the red power light comes on, but no picture or sound.
water from air conditioner dripped on back of 56in.toshiba big screen.now its has no sound or picture.its been sitting for 2yrs and has had just a good as picture a smy flat panel.every 1 says im stupid for keeping it but iwould like to know if it is doable by me.i believe i could do it if i knew what part i needed.thx
Aug 28, 2008 | Televison & Video
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
I have a toshiba theatre view 52-54 in.? There is no picture-it seems like the tv is off but the power button light keeps blinking. Tried using remote and button on tv. neither works.
Same problem with mine. I find that if i unplug it and let it sit for about 15 minutes ( let the capacitor drain?) i can plug it back in and it automatically comes back on and works fine till I want to turn it off again and it goes right back to the flashing power light.
I bought an on/off remote for the wall oulet and it makes a great work-around.
May 18, 2008 | Televison & Video
Tv picture
Solder any / all bad connects in power supply,vertical,horiz &
video circuitry,esp. regulator IC's..................T.
Jan 09, 2008 | Toshiba 32AF43 32" TV
Televison & Video Logo
131 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
