Hello Daniel, I suggest you start with a new needle. Back off the needle thread tension and the bobbin thread tension to a minimum and see how it sews. If it does not ravel the thread, you can increase the tensions until you acquire the stitch you want.
http://www.instructables.com/id/How-to-Thread-a-Sewing-Machine/ check out this link.. it is described clearly with the help of images...
OR try to do by reading these steps..
Step 1
Raise the needle to its highest position by turning the handwheel toward you.
Step 2
Raise
the presser foot. This will allow the thread to easily pass through the
threading points and will prevent the machine needle from becoming
unthreaded when you begin to stitch.
Step 3
Place
a spool of thread on the spool pin located at the top of your sewing
machine. If the spool pin runs horizontally, secure the spool of thread
with the cap provided.
Step 4
Take
hold of the thread end and pass it through the designated threading
points on the top of the machine casing, then down toward the tension
assembly. The tension assembly is located on the left side of the
machine and controls the flow of thread.
Step 5
Take
the thread under the tension assembly and back up through the next
threading point at the top left of the machine. Make sure the thread
has passed between two tension discs as well as the hook that may be
attached to the left side of the tension dial.
Step 6
Push
the thread end through the lever at the top left of the machine, if
applicable, and down through the threading points at bottom left and
above the needle.
Step 7
Thread the needle from the front or back of the needle. The threading direction will depend on your machine type.
Step 8
Pull a few inches of thread through the eye of the needle and pull the thread to your left.
Step 9
Insert
a wound bobbin into the machine, if necessary, and close the throat
plate. A few inches of bobbin thread should be pulled out to the right
and sticking out from under the closed throat plate.
Step 10
Take hold of the thread that has been threaded through the machine needle.
Step 11
Rotate the hand wheel toward you until the needle disappears into the bobbin case.
Step 12
Keep
holding on to the thread and move the hand wheel so the needle is once
again at its highest position. As the needle rises, a loop of bobbin
thread will come up as well.
Step 13
Pull the thread out toward your left to draw the bobbin thread loop further out of the bobbin case.
Step 14 Let
the top thread go and pull the bobbin thread up until the end comes up.
Pull the top and bottom threads under the presser foot and to the back
and right of the machine.
birdsnest refers to a mess of thread on the underside of fabric when you start sewing (after a few stitches all looks good). if this is the case and it is happening during embroidery, switch off jump stitch thread cutting.
if it happens at the start of normal sewing, either hold your needle thread when you start sewing or make sure the needle thread is under the presser foot and held by the presser foot when you start sewing. this way you will have an inch or so of thread on top of your fabric which you can trim instead of a mess underneath.
if there is a mess underneath for more than first few stitches, either your check spring in the needle tension area is set incorrectly, or your needle tension is set too loose (adjustable in sevice menu by tech only) or there is foreign matter caught in tension assembly preventing proper tension.
Yes, but it is a good basic machine. Here's how to thread it:
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
all machines thread the same. TTN tension,take up,needle.
Beginning with the spool, guide the
thread through the thread guides to the tension assembly. Pull the thread
through the tension assembly and test it to make sure the tension is working
correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or
something in the middle. Raise the presser foot and pull the thread through the
tension. It should pull easily!! Lower the presser foot and pull the thread. It
should pull noticeably harder.) If it passes this test, continue up through the
take up lever,then down through the thread guides to the needle. Make sure your
needle is fully inserted and turned the correct way.( If you load your bobbin
case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT.
There are some exceptions. If you have a newer style drop in bobbin or your
bobbin case loads in the front then the rule is FLAT to the BACK.
Normal
0
font-size:10.0pt;
correctly.
Rethread the machine following these directions: all machines thread the same. TTN tension,take up,needle.
correctly.
bobbin case loads in the front then the rule is FLAT to the BACK. Remove the bobbin case and bobbin. Pull on the bobbin thread to make sure it doesn't pull too hard. It should have some tension on it but not a lot. Insert the bobbin and bobbin case into the hook assembly and pull on the bobbin thread again.The tension should still be about the same. If it is tight, you need to look at the bottom of the pin that the bobbin case sits on and see if there are any threads looped around it. If there are , you need to remove them. Hold the top thread , turn the hand wheel and see if the thread is catching someplace around the hook assembly. If it pulls the thread up easily, put some fabric in it and see how it works. Make sure the thread is through the take up lever. sewman7
correctly.
needle is fully inserted and turned the correct way.Industrial needle shave no flat side. You need to find the long groove on the needle and insert it so that it is on the left.Thread the needle left to right. Draw up your bobbin thread and begin. sewman7
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the
tension assembly. Pull the thread through the tension assembly and test it to
make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or
