Question about Canon PowerShot A510 Digital Camera
Camera lense/power Camera lense is stuck out. When I turn it on the lense goes in and then comes out, a main picture apears, green light comes on and then it powers off with the lense stuck out. It will only stay on if I have it in play back mode. Please help! Phil D. PS - I have the PowerShot SD400
  • Canon Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 18, 2008
My coolpix L810 won't turn on. Green light comes on but goes out. Can't see screen. Lense was frozen but plugged into computer and closed.
have the battery full charge? sometime the battery is not charged although the charging indicator is full charge, maybe the battery is shorted out.
May 04, 2013 | Nikon COOLPIX L810
Nikon l810 doesnt switch on, green light comes on then goes off
you may need to set the timer longr to take the picture also be sure to open the lenses or remove the batttery yt reset be sure to used right can of batterys
Aug 27, 2012 | Nikon COOLPIX L810
My new camera (samsung TL205) will not turn on, when i press the power button I hear a chiming sound but the camera will not power on.
mine is doing the same thing. but my lense wont even close. and when i press the button to power on the green light comes on then beeps, then goes off. so if you get a word on how to fix it let me know.
River
Dec 24, 2010 | Samsung DualView TL220 Digital Camera
The stupid thing won't power up anymore. I try and cut it on and the green light just flickers then goes off. it froze when the lens was out too which means its been stuck that way for a while. I didn't...
I found that cheap (new) batteries will not work in my camera. Duracell or Rayovac seem to work best.
I added 2 (new) cheaper batteries it took 1 picture the lenses would not retract and the battery light flickered. I found 2 new Durnacell and it works fine now. Hope this helps.
Oct 14, 2009 | Samsung S860 Digital Camera
Lense was stuck out did what toothy said now the lense is stuck i
Hi!
Please follow the troubleshooting given below to resolve the issue:
(a) Turn off the Camera and remove the Battery then press and hold the power button for 30 seconds.
(b) Then, reinsert the Battery and turn the Camera ON. Please make sure that the Battery is fully charged.
(c) Next, press and hold the Reset button for 30 seconds located above the DC-in jack on the Camera using a sharp pointed object.
If the Camera doesn't operate normally even after performing all the above mentioned steps then service will be required.
Aug 23, 2009 | Sony Cyber-Shot DSC-P72 Digital Camera
Camera immediatly shuts off and lense goes back in.
Sounds to me that ist is more of a charger issue. Try to borrow another charger and see if that works or not.
Jun 11, 2009 | Kodak EASYSHARE M1063 Digital Camera
Finepix a345 will not switch on
Does it power up in playback mode? If you can view pictures try switching over to camera mode and see if the lense will extend. if not then your lens is possibly stuck. possible solution in "THE ONLY WAY I KNOW HOW..." In my tips n tricks section. Also is my email if you want some pictures of an A345 opened up. Cheers.
Apr 28, 2009 | Fuji FinePix A345 Digital Camera
Canon G7 lense does not extend fully but it is NOT e18
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
My L200 samsung camara is frozen and the lens are stuck out
I had the same problem - and wondered if if might be that the battery didn't have enough 'grunt' to close the lense - so I am charging it via the actual charger (rather than through the computer) and sure enough, I turned it on and then off, and the lense closed. The green light comes on when I plug the camera into the computer to download photos, and I thought this was therefore charging the battery, but maybe it doesn't charge it properly. Anyway, my lense is now closed and the battery is still charging (light is still red). Good luck.
Jan 06, 2009 | Samsung L200 Digital Camera
Power/lens Problems
it seems that the lense movement is jammed. Have you dropped the camera? just have a close look from the front side of the camera, does the lense assembly seems to be pressed or moved aside by some extra preassure? if no physical disalingment is visible may be some sand or dust partical is obstructing the movement of the lense assambly. needs a help from camera repair shop.
Sep 08, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Canon PowerShot A510 Digital Camera Logo
138 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
