The firsy thing u schold do is check to make sure your wireless switch it is for gateways iit is usally on the side on your computer
Fast and easy method is to get setup disk internet service provider, check device manager > network adapters, control panel network connections, configure LAN/wireless router.
SOURCE: Wireless Lan not working
go to ur network connections, and Repair ur network adapter by rightclicking on it, and choose repair, hopefully this fixes ur problem
SOURCE: wireless connection to my laptop
you can't partially wipe your system
do you want to format
open control panel network connections see if network shows then right click then enable if you don't see enable then click repair
check devices see if your wireless still shows maybe needs updated
let me know if you are connected you may need to reinstall driver
i can help
SOURCE: My acer laptop cannot conect to wireless networks
This many not help because we were trying to connect to our home network which is secure and it kept failing. We finally found if we went into the Manage Wireless Networks and double-clicked on the network name to bring up properties and then went to the security tab and found that the security type was set to open instead of shared. We set this to shared and then it worked. Check yours and if it is set to shared maybe you need to set it to open to get it to work with unsecure networks.
