Airnet AWR014G8 Wireless Router Logo
Posted on Sep 09, 2017
My Router reset very often. When I set the DHCP=DISable, the reset stops. But of course I must use DHCP=ENable for automatic IP. It will reset as often as every min. I am not sure if the router got any attack or power surge. I didn't notice any. The problem started since last week (a very windy day) after my router suddenly reset all setting to default. Thanks.
Wrt54g2 dhcp problem
You must enable the DHCP setting on wireless router if you've configured the computer's wireless adapter to obtain an IP address automatically. If not you will get the "failed to acquire an IP address" error when you try to connect to wireless network! Also don't forget to configure big enough IP range on router's DHCP setting, because the router won't be able to assign IP to 6 computers if you only configured 5 IP space on router.
Give automatic IP to panasonic DP 4510
Does your router set up to give automatic IP addresses ? (Does DHCP set and running )
?f no, please enable DHCP on your router, then your printer will get an automatic IP.
please do not forget to set your network adapter to receive IP automatically by simply switching it from manual to automatic in network adapter properties > IP settings.
On my windows vista dell laptop it say limited acess to linksys
"Limited access or no connectivity" message comes when there is issue in ip configuration for that enable DHCP in router then set ip get automatic in your windows network adapter's tcp ip property. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then enable DHCP save settings and restart router then go to your windows network adapter tcp ip property then set ip get automatic.Then it will work fine. Let me know if you need further assistance. Thanks for using FixYa.
1helpful
Switch D-Link DES-1024R + My problem is not gateways automatic
No It's not virus . It is issue of ip address in your computer. You can set ip address with 2 method static and DHCP. For DHCP you need to enable it in router. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on DHCP and enable so you can get ip from router.Enable "ip get automatic in network adapter tcp ip property. If you want to ser static ip in tcp ip then gateway ip set to router ip if your router ip is 192.168.1.1 then your computer ip is 192.168.1.3 subnetmask 255.255.255.0 and gateway as 192.168.1.1 Then you can access internet Let me know if you need further assistance. Thanks for using FixYa.
I have a yellow machine p400t and i need to give it a static IP address and do this through a linksys router. how do i go about this? do i need to attach it to a computer?
Yes, it must be attached to the network 0. Install the yellow machine software on the PC 1.Log on to the Yellow Machine Manager. Go to “Logging On To Yellow Machine Manager” on page 8. 2.From the Yellow Machine Manager, click Network > Network Interfaces. The Network Interfaces window appears. 3.Click Edit. 4.Select Yes to Enable LAN Interface. Default: Yes (Enabled) • If you select No, all other LAN option fields are blocked. • If you disable the LAN Interface, the only access to the Yellow Machine appliance is through the WAN port. Anthology Solutions does not recommend this configuration. 5.Check Enable DHCP Service if the DHCP service is needed for the PCs attached to the Yellow Machine appliance’s LAN ports. This setting makes the Yellow Machine appliance the DHCP server for your LAN (or sub-network), providing IP addresses dynamically for the clients connected to the LAN ports. Default: Checked (Disabled) 6.Select either Obtain IP Address Automatically from DHCP Server, or Static IP Address. Default: Static IP Address • Choose Obtain IP Address Automatically from DHCP Server if your Yellow Machine appliance connects to either a router that has DHCP service enabled or to a cable modem. This setting makes the Yellow Machine appliance a DHCP client on your network. • Obtain IP Address from ADSL provider is greyed out. • Choose Static IP Address if your network is locally defined and controlled and does not use DHCP services. Type the IP address manually. 7.Specify IP address and Subnet mask if you selected a Static IP Address, and click Apply. 8.Click Yes to confirm, No to abort. The changes takes affect within five seconds after the network interface change notice appears.
Unable to connect to DHCP server. getting 169.254 ip Have already tried the following: unplug/ reset reboot router; ipconfig /release /renew; Run MBAM Version 1.43; System restore to a date when connection...
Whew! Awesome troubleshooting work there.
When it's configured for DHCP, go to the Internet Protocol (TCP/IP) Properties and hit Advanced to bring up the "Advanced TCP/IP Properties" dialog.
Under the IP Settings tab, the top panel should be "IP addresses" and should have "DHCP Enabled" as the only entry, and the default gateway should be blank.
If both of those are correct, then I have one other question for you:
When you manually set an IP, are you able to use the network? If so, are you able to ping the DHCP server's address?
If so, then my guess would be that the DHCP server has a stale record for your Dell's MAC address.
Post back with the "Add Comment" button here and we'll get it working for you.
2answers
Trying to secure my wireless linksys....rebooted router...responds...There is an IP address conflict with another system on network..thanks
i get this all time when i am on wifi with my 360 and iphone at the same time try and shutdown all things wifi in ur house go to router setting and give them a little check make sure ip is set to automatic
1helpful
RE: My posted. Connecting DSL/Router to DIR-628 internet router
Installing a router to work as the second one on a home networkrequires special configuration. Do the following on the second routerto ensure it (and the devices attached) function properly:1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode.Note that some home wireless routers do not support client mode; thesemust be connected by cable. Check your router documentation for detailson its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP addresssetting. Often, these default IP addresses will not work in a tworouter environment. Check the second router's IP address value andreset it if necessary to work within the valid address range of thefirst router (and to not conflict with any other device on the network).
3. Disable DHCP- To avoid IP address conflicts between all of the devices on the homenetwork, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
(My netgear router supports client mode. The 2wire supports bridged and router mode. My 2wire is the main router. I set up my netgear using my laptop. Once you change the address on the router.. You will only be able to directly access through the main router to the 2701.)
Configure your 2701 IP address to a static address in the 192.168.2.1 range and diable DHCP. Only 1 router can run the DHCP service. To disable Dhcp on the 2701.... log on to 2701> click on home network>advanced settings>uncheck enable DHCP>Next section is Public routed subinterface...Check enable and Aout Firewall Open>Input your main router address and mask>save config..
This worked with the Netgear router.. May not with your router. Good Luck! Hope this helps!
Static config
DHCP is superior to Static IP in every conceivable way. It is not any slower. However, when you FIRST connect to a dynamic ip router, your computer and the router have to handshake a bit, which takes a few seconds.
After that, they are at the identical speed. DHCP shields you from all sorts of trouble like colliding IP addresses, DNS server, subnet masks and gateways. It is way better and more reliable to go with DHCP.
Static ip is only useful if you *need* static ip, e.g. if you want to host a server on your router and you need the computer's dns server to stay the same.
That said, if you still want to use a static ip, here's how:
Simply disable the DHCP server in the router's settings. Also, go into the router's "status" page and take note of the DNS ADDRESS(S). You will need this later.
(Please note, if you disable the dhcp server, the only way to get back into your router and re-enable it is to use static ip on the computer, or to hard reset the router)
Then, you configure each computer connected to the router to use a static IP as opposed to obtaining it automatically. To do this in windows XP:
Go to start->control panel->network connections
Right click on Local Area Connection and go to Properties
Select "Internet Protocol (TCP/IP)" from the listbox
Click Properties
In the general tab, tick the radio box "Use the following IP address"
Type in the ip adderss you want (e.g. 192.168.0.105)
Type in 255.255.255.0 as the subnet mask
Leave the default gateway blank
Type the ip address of the DNS server you took note of earlier into the "Preferred DNS" section at the bottom of the form.
Click ok and ok and ok until you're out of all the boxes. Your IP is now static, and cross your fingers. If you did everything correct, it will work. If not, check your settings.
2answers
Cant accses router
Pressing and holding the reset button on the router for about 5 seconds should reset the router, but you may need to connect with the router via an RJ45 network cable incase the wireless is not able to set it up The default ip address of the router should then be 192.168.2.1. do not use the windows repair wizard as this totally messes up your pcs ip address, make sure that your network wireless and wired adapters, are set to obtain an ip address automatically You shouldnt change the PPOE or PPOA settings, as they are the settings on which your ISP allows your router to connect to the server. Manually entering an ip address will effect the address of the router so keep the settings as enable DHCP to assign ip addresses automatically. Ensure when you have it running you save the settings so as you can reinstall them if neccasary.
Top Airnet Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Airnet Computer and Internet Expert? Answer questions, earn points and help others
