Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Stuck Lens I fell on my camera just recently and the lens is stuck open half way. When you power it on it moves a bit to the side and up, then to the other side and up and then beeps couple of times. You can view all the pictures and see the opening screen when you turn it on on picture-taking mode but it won't open up completely. Is it possible to fix? If so how?
  • Canon Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 18, 2008
Dropped the Camera, Lens is stuck open
I already tried posting this but I think it falied. Just in case, here it is again!
I just now fixed my own Nikon S220 (very similar to 210) which suffered the same fate as yours. However, I laid my camera down on a cushioned foot-rest (you could use a couch cushion or pillow on a table) with the lens facing UP, pressed down on both sides of lens front gently yet firmly, and BAM, the lens went back in all the way. I turned the power back on and the camera is good as new (except for the small dent from the fall of course).
I suggest you try this before spending $100 on repairs and/or buying a new camera!
Sep 09, 2009 | Nikon Coolpix S210 Digital Camera
Lens stuck
hi...
The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u rate me!!!
Jul 13, 2009 | Samsung BL103 Digital Camera
My digital Sony camera fell down Lens got stuck
    As in short answer you have to replace the optical lens assymbly.Because due to heavy jurk its motor called sledge motor stsrt malfunctioning and it can not be changed component level. For this please contact any SONY SERVICE CENTRE nearby to you.
Hope you will understand.
Thanks for using FIXYA!
Apr 28, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Camera lens stuck
Look at some of my posts today.
This may be that the lens is off track and may be able to be pushed back by a little force as you start the camera....see my other posts on this problem.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
Kodak Easy Share Z1275 stuck lens
I have a Kodak 1275. Green light would go on the off and lens was stuck open. Now for solution that worked for me. Get a can of compressed air, like what you use for computer keyboards. Blow the compressed air all around your stuck open lens, not to fast and switch directions of where you blow air around stuck opened lens. Make sure batteries are fresh and fully charged. Tap your camera against the palm of your hand twice, not to hard or you may damage instead of jarring lens lose. Next lay your camera on a table lens facing up, push power button on so camera will try to auto focus and lens should reseat itself and lens should move freely. It doesn`t have to look dirty or dusty, little tiny particles can cause the lens to get stuck and shut off fast because it is a safety feature. If this does not work try plugging your camera into computer so the lcd screen does not try to go on , thus giving even more power to get your lens moving . Do not try to force it closed by pushing or twisting with your hand or you may cause damage that will cost as much as the camera to fix.
Jun 05, 2008 | Kodak EasyShare Z1275 Digital Camera
Sony dsc-w55 fell and the lens is stuck
Use bit more force to push or pull the lens as lens has been damaged. If applying bit more force lens goes to working, u saved $$$ otherwise, new lens option is always available at Sony repair shops.
May 30, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Lens cover stuck open
I recently had the lens cover stick partly open.  There are 4 segments to the lens cover, and if we number them from the top, number 2 was not closing.
I gently flicked the segments a few times, in case there was a grain of dirt causing it to stick (although the camera has never been in a dirty or dusty environment).  This caused the lens cover to close fully each time, but now it would not open fully, segment 1 would not open, although it would stay open if moved by finger.
Anyway, after a bit of fiddling, I got it working properly again.  The way that the lens cover appears to work is that only segments 2 and 3 are pushed open or shut by springs, segments 1 and 4 are pushed open and shut by tiny tabs that catch on segments 2 and 3.  If the segments somehow get pushed out of alignment, then they either bind (causing the cover not to shut), or they get disconnected (causing the cover not to open fully.
Now I am not sure exactly what I did to get the mechanism form the stuck open state to the not opening state, but from there the way to fix it is to:
-With the lens open...
- Hold segment 2 in the closed position with firm finger pressure (which will tend to push it towards the lens).
- Push segment 1 towards the open position until you can see that it has cleared the edge of segment 2.
- Lift segment 2 way from the lens so that it will rub past segment 1 as you...
- Move segment 1 to the open position.
- Repeat if necessary to get the technique right.
I can't provide any guarantees, and I am not about to repeat the excercise on my camera, but it was a lot easier than sending it off for repair.
Dec 12, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Optio S5i Stuck Lens
Hi: First of all, with that behavior, your lens are stuck. Probably the problem was on the assembly. Try to disassemble and assemble them again. Regards
May 16, 2006 | Pentax Optio S5i Digital Camera
Optio 450 Lens Stuck Problem
the lens cover gets stuck sometimes. It just needs a gentle touch and it opens up. Only happened once to me. In my case it happened after my daughter held onto the camera with her finger on the lens cover.
Sep 08, 2005 | Pentax Optio 450 Digital Camera
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
105 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
