Question about GE GSL25JFPBS Side by Side Refrigerator
Power problem all of a sudden my fridge made a spark sound and stopped working. Where would i check for fuse or is there something else i would look for. any input would be greatly appreciated. thank you in advance
Thanks for reply do know anywhere i could find the proper diagrams so i could check compressor
Posted on May 18, 2008
The short inside of the compressor must be found please check with ohmeter the two coils inside with proper diagrams some comes glued in side. please diconnect the ac input
I have power going into my fridge freezer but the lights inside the fridge are not coming on and the compressor is not running and the items in the freezer are thawing out. Is there a trip switch?
sounds like possible inline fuse or electronic board is fried ,kif power to unit will have to check for power at electronic {control} board
Jun 09, 2016 | Refrigerators
My fridge has suddenly stopped working.
check mains power fuse
I may be a capacitor for the compressor
have a fridge mechanic check it out.
May 05, 2015 | Refrigerators
Hi, on my 02 Land Rover Freelander HSE, my air con/ heating fan has completely stopped working - Any ideas on what it could be?
ck your heater fan fuse first , that might have 2 places with fuses for that , if they are not blown look for maybe a relay for it also , next see if you are getting power to your heater fan if you are then you fan will need replaced but I really never seen a fan go unless there was something stopping it from turning keep e posted
Sep 21, 2014 | 2002 Land Rover Freelander
Amana refrigerator sparked by plug and now won"t turn on even when plugged into another outlet with extension cord should i repair or replace?
i am in the uk so i dont no if this will sound right,but have you tried changing the fuse in the plug of the fridge? make sure you put the same size fuse back in.
Oct 12, 2017 | Kenmore Refrigerators
I have a 2000 Saturn LS2 ALL OF A SUDDEN THE WHOLE IS SHAKING ESPECIALLY WHEN I STOP AT LIGHTS OR STOP SIGNS...WHERE DO WE CHECK THE TRANSMISSION FLUID WE CHECK EVERYTHING ELSE
doesn't sound like transmission fluid in my experience if transmission fluid is low your gears will slip or not work at all, sound to me your spark plugs or bad gas or something in that order.
Apr 27, 2011 | Saturn SL2 Cars & Trucks
Lost power, now fridge won't work.
check all the fuses maybe blown up due to high amper of sudden power resume.
Aug 15, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore fridge started having sparks and has an unpleasant smell
the compressor is asealed unit and wont cause any smell but it does have a push on starter on the compressor pins under the cover (most likely cause)
Possible other faults are defrost element or defrost timer
Jul 27, 2009 | Refrigerators
Hotpoint FFA71 fridge and freezer suddenly stopped working
Sounds as though the compressor has stopped working. It feeds both compartments with control from a printed circuit above the top door.Where all your red lights are ablaze! (This can be replaced by removing the 2 screws and "clicking" out the small panel) Check that the compressor is running at the bottom rear of the fridge/freezer before anything else.
Jun 30, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refridge stopped working after a power surge
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
Apr 03, 2009 | Refrigerators
GE GSL25JFPBS Side by Side Refrigerator Logo
76 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
