Back to:
Tags:
RCA TruFlat  27F520T 27
Turns off by itself!!! (by 2 users)
posted by 15hans on May 18, 2008
The tv will turn off by itself while watching a program. It makes a loud noise. You can sometimes turn the tv back on but it will do the same thing again. Other times it will not come back on. You have a black screen.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on May 18, 2008
off color distortion on tv then it shut off turn back on it will shut off again
Solution #1
posted on May 28, 2008
Not Rated (0)
The witch
Rank:Wiz Wiz
Rating: 84%, 304 votes
The flyback transformer are damaged.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Turns off by itself!!!:
I don't want to Accept this solution
Can you Help with these Standard Televisions problems?
RCA TruFlat 27F520T 27" TV
Had a visible white vertical line at least 5 inches on top...
I have a RCA 27" SDTV that's less than a year and a...
my tru flat says MONO -- i've pressed every possible...
Hi, I just got a roommate and I never used the microphone...
we have a univeral remote for our rca tru flat tv but we...
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
