Instruction manual or help with tv. we did something and now we can not retrieve certain channels.
  • 8,617 Answers
I will need the model number of your set in order to help you out with your problem. Let me know what the model number is.
Posted on May 18, 2008
Truetech 10 inch under the counter tv is stuck on channel 2. I need 3. Channel buttons on tv & remote do not change 2 to channel 3. Unplugging, Resetting hasn't worked Any ideas?
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Jan 08, 2017 | Televison & Video
I've tried to set up a Bose remote to my TV and B Ray player. I can get the programme change, menu and the channel guide working but not the volume + or - .I've tried other codes as instructed.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Jan 06, 2017 | Bose Televison & Video
Troubleshooting tv
you need to buy tv converter box,
Jun 16, 2014 | Televison & Video
I have a 39 inch element tv i cant program the cable channels
Typically you can access the menu, select "tuner" or something similar, make sure you're selected either on CATV or ANT (or similar), then do a channel scan. Should be pretty straightforward. Oh, and make sure you actually HAVE cable. If it's digital cable, you may need an external converter box for it to work.
Feb 23, 2014 | Televison & Video
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
I can't get my Comcast remote control to sync up with this sylvania 32in HD tv. I tried every code in the Comcast DVR manual under sylvania tv's and nothing, I would love a fix to this problem.
the tv is likely to be generic in nature i.e. parts used by many manufacturers. if you knew what tv builder actually designed it you could find the code. does the remote have a search feature if so use it, it should find something that operates most tv functions eventually
Mar 09, 2013 | Televison & Video
My panasonic DMR-EZ45V will not auto -setup restart the dvb freeview channels it goes through the channel numbers but they do not download only the anologue channels download. it is connected to a...
I have one of these with the same problem. I couldn't find any others with answers but there are people giving answers about the DMR-EX75 showing the same problem due to power supply decoupling capacitor failure.
I just ordered a manual for mine from manualzone.com to try to locate the culprits. - Wish me luck!
Jul 25, 2011 | Televison & Video
How to unlock e.tv in mytv decoder and how to open scrambled channels in DStv?
How to unlock etv and scrambled channels on Mystrong Decoder
Nov 15, 2010 | Televison & Video
Need instructions to add TV button to AKB36157102
1. While pressing and holding down the TV POWER button, press the CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on (or turned off if you had it on). 2. Release TV POWER button when the TV turns on or off. The remote's TV POWER button will now control the TV.
Jul 19, 2009 | Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
