Question about Passport 8500 Radar Detector
8500 radar display
Display stuck in "AUTO". Have attempted RESET numerous times with same result. Radar will post normally and display "AUTO". Pressing top two buttons for 2 seconds per instruction also failed to progress beyond AUTO" mode. Several times, by pressing top two buttons and cycling on/off dial, I was able to get "PROGRAM" and gone through the routine per insturctions in the manual. Upon completion, it will revert back to 'AUTO" and freeze.
Seems like software problem.
Anyone has same experience and able to suggest soultions?
Thanks
  • cuntofa Dec 30, 2008
    same problem as dreamdreamer. if i start it with both program buttons pressed the display reads RESET then to REV: 15
  • 134 Answers
I take it that pressing the 8500's City button won't switch sensitivity modes? If so, and if performing a RESET doesn't resolve this problem, then either the firmware is corrupted or (most likely) the micro-switch for the City button has gone bad and needs to either be replaced or possibly resoldered so that its two terminals are once again making full contact with the solder pads on the circuit board.
Posted on Mar 19, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
My escort passport 8500 says "service required" after it starts up. what do i do?
Your radar detector is detecting a problem with part of the circuit during the start up - or boot sequence. Typically, these complex devices run a quick diagnostic check when starting up. If any result isn't as expected, you get a warning and in this case - a message indicating it needs servicing.
There is little that you can do to the detector to locate the problem; much less fix it. You could try to shut it off and turn on again to see if the problem goes away - but it probably won't. Your best bet is to return it to the factory for repair. You could continue to use it - but if the part of the detector that failed has to do with displaying or detecting radar sources, you may be in for an expensive surprise when you get pulled over for speeding.
Contact Escort radar customer service to go over your options.
I hope this helps - good luck!
Nov 15, 2010 | Passport 8500 Radar Detector
Says to get service
The service message indicates something isn't working as expected. This usually happens right after powering on, when the detector runs its self-check and receives an unexpected result. Continuing to rely on this device for radar warnings could be expensive.
Contact Escort Radar Support to arrange for service to restore reliable operation.
I hope this helps.
Sep 23, 2010 | Passport 8500 Radar Detector
Got a ticket, passport never made a sound
You may have received a laser hit or a qucik shot on the radar. We don't normally keep the radar on constant - a click of the button sometimes real fast will grab your speed, lock on the display and then the signal will cease to omit.
You may also want to check to see if you are set on city of highway.
Dec 11, 2009 | Passport 8500 Radar Detector
My 8500 Radar more and more often displays service required message. How do I fix it? Thanks
This is due to failing the calibration test.Perhaps you can reprogram it or will have to return for sevicing.
here is the brochere link.
http://www.escortradar.com/pdf/8500x50manual.pdf
Oct 09, 2009 | Passport 8500 Radar Detector
Passport Radar service required
The internal diagnostics have detected a problem with the detector. You should contact Escort Customer Service directly for assistance, below:
http://www.escortradar.com/customer-service.php
Sep 27, 2009 | Passport 8500 Radar Detector
K and f off
Power off the RD using its power button. Then hold down the two programming buttons and press the power button while holding down these the two programming buttons. Release all three buttons once RESET is displayed on the RD's display. Your 8500 has now been reset back to the original factory settings with all bands enabled. You can download a PDF duplicate of the original user manual from Escort's web site.
Feb 14, 2009 | Passport 8500 Radar Detector
Display won't light
This is most likely due to a cold solder joint for one of the display leads where they are soldered to the edge of the circuit board. Or, possibly, the display itself has gone bad.
May 27, 2008 | Passport 8500 Radar Detector
Service required
Hold down all three buttons and the device will reset itself.
Dec 15, 2007 | Passport 8500 Radar Detector
Passport 8500 Radar Detector Logo
277 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
John Nolan
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
