Question about Sony Handycam DCR-DVD201 DVD Camcorder
My camcorder files show up as a .bup type file...what is that
What is a .bup file that is on my Sony disc when I load it on my computer
  • 10,594 Answers
'''BUP''' (Back UP) is the filename extension of some files stored on video DVD on the disc. The BUP files are used in the event that the corresponding IFO file is unreadable, perhaps due to a scratch on the surface of the disc.
Posted on Jun 01, 2008
Can not get video files from a mini dis dcr dvd 108 handycam when I try to import to my pc it says does not support this dis i was using usb cable to pc with sony's software thanks jim
First make sure to finalize recorded disc in camcorder, finalization option is available in camcorder menu and will be enable by powering camcorder with AC charger/ adapter.
Now you can transfer movie files in computer or put recorded disc in computer dvd rom and copy files.
Jul 31, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Tip
Blu-ray to iPhone 4 Converter,DVD IFO to iPhone 4 on Mac-Rip DVD to iPhone 4...
What is DVD IFO?
You will find VIDEO_TS folder and AUDIO_TS on a DVD-Video disc. The VIDEO_TS folder includes the files and data for the DVD movie. You will find three kinds of files: BUP, VOB and IFO. The VOB file contains video and audio data. The IFO file contains video navigation information like chapters, while the BUP file is the backup file of IFO.
To load a DVD IFO file, it indicates that we can load part of the DVD disc for conversion. You will find VIDEO_TS.IFO, which generally includes all the information of the disc. The VTS_01_0.IFO usually is the main movie and other IFO files as copyright notice, extras and so on.
How to convert DVD IFO to iPhone 4?
A good Mac DVD IFO to iPhone 4 converter shall not only work on Leopard and Snow Leopard, but also be able to convert DVD IFO from DVD disc and DVD IFO from DVD-Video file structure folder on hard drive. Aunsoft Blu-ray Ripper for Mac is the recommended Mac DVD IFO to iPhone 4 converter for you to convert the videos as you like.
Step 1. Load DVD IFO to Aunsoft Blu-ray Ripper for Mac.
Download Mac DVD IFO to iPhone 4 converter, insert DVD disc to DVD-Rom and click the IFO/ISO button. You will face the Mac folder, choose the DVD from DEVICE, and open the VIDEO_TS folder to find IFO files. Here I choose VIDEO_TS.IFO for conversion.
Step 2. Choose iPhone 4 720p video output.
Click the Format option and you will find several profiles. Choose iPhone > iPhone 4 H.264 720P(*.mp4) for the output video.
Step 3. Choose subtitle for iPhone 4 video. (optional)
Click the "Subtitle" option and choose the preferred subtitle language for display on iPhone 4 video.
Tips: The subtitle option is generally only available for main movies. Some extras like interview may also include subtitles selection.
Step 4. Convert DVD IFO to iPhone 4.
Click the convert button to start converting DVD IFO to iPhone 4 720p .mp4 videos. You can also only make sure the checkbox of main movie on the list is ticked to convert the main movie only.
Tips:
1. You can load the entire DVD disc from DVD Rom directly by clicking the BD/DVD Rom button.
2. If you are using the Windows computer, you can try the Windows version of DVD IFO to iPhone 4 converter.
on Jul 06, 2010 | Cameras
Is there a way to hook up a usb cable to a Sony Handycam DVD205?
unfortunately,no. the dvd camcorder was designed for easy dvd disc recording w/o usb or computer connectivity (it doesn't have usb port for connection). comparable models that has the usb jack are dcrdvd305 aqnd dcrdvd755 (which cost more). but don't loose hope.other options to transfer videos from cam to pc is by using the dvd disc (make sure you finalize it) and your computer's dvd drive (make sure it has supports 8cm disc and the disc tray in the right orientation to take the disc so it won't fall out). once inside the drive.open or explore the disc and copy and paste video files saved on the usual video_ts folder or the .vob files. if you need to playback the copied files you can simply change the file name to .mpg or use a file conversion software (which you can easily download for free online, use free file conversion as your search phrase) to convert files to a file format you need for editing purposes. another way to go is to use the supplied a/v cable. this type of connection would need a supporting software and hardware installed in your computer. an a/v capture card should be installed and a compatible video capturing application would be needed. hope this helps.thanks:)
Jun 01, 2010 | Sony Handycam DCR-DVD205 DVD Camcorder
Vob ifo bup files to burn as dvd trouble
Try this:
Get the Nero 9 application
Install it on your computer
Create a Video Disk
And browse the folder of the VOB files Add it to burn the disk
Select Burn to burn the DVD ....
You may also try to put in a blank dvd and copy all the files on the DVD drive
Select burn these files on the disk
This should work
Regards Soumajit
Mar 12, 2010 | Computers & Internet
How do i transfer files to my computer and to a DVD? I have a dcr-hc42 ntsc. I'm unable to locate my manual and disc
Do a search (google) for Sony.com. It has your model listed to down load software and a pdf file for the manual.
Nov 12, 2009 | Sony Handycam DCR-HC42E Mini DV Digital...
Retrieve video from camcorder disc
try to finallize from cpu and cam. usually that means file is corrupt if so try in simillar cam to retrive video
Jun 01, 2009 | Sony Handycam DCR-DVD201 DVD Camcorder
I can´t download the files to my computer
Not sure if this helps but; when the camcorder is connected to the computer, press the "burn to disc" button on the docking station.
May 03, 2009 | Sony Handycam DCR-SR42 Camcorder
HOW TO CONVERT A IFO , BUP and VRO file.
 For read your files in your laptop, you con download vlc and open your file *.vro.
For converting you must use software like AVS Video Converter 6 or TMPGEnc DVD Author 3 with DivX Authoring and other.
Feb 03, 2009 | Sharp Televison & Video
Transfering Videos to my computer?
Sounds like you have conflicting file associations, which means that some types of files open in one player and others in another. However, this isn't your main problem.
To play the DVD file on the pc you need to have the .ifo, .vob and the .bup files in the same directory as well as the video_ts files etc. Easiest way to do it is to copy ALL of the files from each disk to a folder on the pc, then you can play them from there and format your disks ready to be re-used.
If you'd like further help with converting the format and sorting out your file associations please post again but the above information should cure your immediate problem.
erch.
Mar 15, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Sony DCR-DVD 108 disc won't play or record
Movies shot DV Camcorder forms mpg files when down loaded in computor and can not be converted to a CD. Problmes comes in conversion of mpg files to AVI, WMV, AVSEQ or MPEG2 etc.
Oct 29, 2007 | Sony Handycam DCR-DVD108 DVD Camcorder
Sony Handycam DCR-DVD201 DVD Camcorder Logo
59 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
