Kodak EasyShare V1003 Digital Camera Logo
Posted on May 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
New camera just got
I know how to get pictures my camera to my computer but i dont know about the videos i tryed everything that i knew how to do but now im stuck
Anonymous
Level 2:
Champion:
  • Expert 203 Answers
  • Posted on May 18, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
203
Questions
Helped
54614
Points
461
Kodak uses a different file extension if i rember and you might need quicktime to play videos-
DCIM folder has got deleted, what do I do ? MY DSC-H20 was infected with viruses, I scannerd it with AVAST and selected the option of deleting the infected files from the system. antivirus apparently...
If all your images are backed up on your computer, just format the media card IN THE CAMERA, and that should re-set everything for you when next you take a photo.
1helpful
Camera says file error when trying to look at pics
Question; Have you tried plugging the camera in to the computer with the usb cord?...If not, leave your memory card in the camera and connect the camera via usb cord into the computer, after a few seconds orso a window will come up asking you"what do you want to do with this device" orso, just close (x) that and click on "start" on the desktop. When that opens, click on " my computer". A window named"my computer" will open up showing several devices (depending how many device you have on your computer). For instance, the hardrive is usually marked (c) disk..Look for a "device" with a name that sounds like your camera and open (double click) that. If you don't recognize any devices, then open them all, one by one, (except the hardrive (c) ) and see if there are any folders in there that seems to represent your picture file orso (mine says 100dcism or something like that, I dont know why lol), double click such file and it will open up. If you then see files named (jpg) etc then those are your pictures. If you are still not sure then double click one and it will open up, if it is a picture then your picture will come up in full view, voila,you found your pics (they are in the file you openend before yopu actually saw the picture come up)...If you still dont see your picture, just close all windows and repeat process on different "discs" ( (c), (f), (g) and any others, except (c) thats the harddrive usually....Once you've located your pictures copy or cut (hover the mouse pointer over the picture you want and right-click then select cut (this removes the file, picture in thid case, from wherever you cut it, or you can copy it(same right-click procedure) and select"copy" this will leave the pic where it was while making a copy you can "paste" anywhere you want them from the place you found them and paste them in to the folder you want ( I sometimes create a new folder on the desktop and put all my files I take from the camera in there, then later I can sort them to seperate the video's from the picture files....For your problem in particular, I would follow these procedures till I found the new files you are trying to load into your computer, when you find those then cut or copy those to wherever you like (ie "my pictures" folder. Once you have them safe there, I would go back to "my computer" and find the disc ( (e), (f), (g) where you found your missing files (pics) and then delete everything on that disc, this will delete and clean your disc, and most likey remove the straggling deleted pics of times past lol...If you know how to defrag then go to the defrag menu, but this time, while camera plugged in via usb, chose the 2 disc visible (unless you have 2 harddrives your camera will be the second one(it will have the same disc letter ( (f) or (e ) for instance as the disc you found your pics on (the disc here is actually the memory card in your camera
15helpful
2answers
How to get pictures off sony cyber shot onto computer using usb
When using Windows Operating System on the Computer, follow the steps given below:
Connect the Camera to the Computer using the supplied USB cable. The Computer will recognize the Camera as a removable drive and list in the Windows Explorer. Press the Windows logo on the keyboard along with the "E" key to open the windows explorer. If the Sony Camera is listed in the explorer as a removable drive then double click on it to open and navigate through the files and folders. Open the "DCIM" for images and "MP_Root" for videos. Once the images and videos are visible, right click on the desired file then select copy. Next, paste the selected file on the hard drive of the Computer.
If you want to select all the files at once then press "CTRL+A", to copy, "CTRL+C" and to paste, "CRTL+V".
Batteries wear out quickly
most cameras use alot of energy so it could be normal but you may be using batteries that dont put out enough voltage. your rechargeable batteries may be wearing out (as they all eventually do). i suggest trying out duracells. the computer may have just reconized the old camera so it knew what to do but since you got a new one, your computer doesnt reconize it.
1helpful
Lost pictures and videos
you probably press the reformat botton and ereased all the pictures on your memory card, i dont think you can get them back
I brought this new camera and just started recording my friend dance and i know how to get pictures on to my computer but i can't figure out how to get the videos i did on to my computer to watch i tryed...
videos have a different file extension than photos and some time windows doesn't recognize it-use software from manuf or tell me what brand camera-try a generic memory card reader and bypass the camera can also work
May 17, 2008 • Cameras
Black screen when trying to take pictures
i just got a new camera the dimagne x50
and i brang it out today and it was working fine it didnt drop or anything
i took a picture then turned it off then i turned it on agian and when it was on the camera format the light kept on blinking yellow for the longest time and wouldnt let me take a picture so i tried the video format and it worked so im just wondering why the video format is working and not the camera ?
has this happened to you? is there any way of fixing it?
Panasonic DMC-LC1 Camera help, Black Screen
Clean everithing around the battery conections, try another battery too, check the polarity (basiks).
Try to use with the computer in webcam mode.
But dont try too hard if the common sence not workig, use the warranty!!!
Playback mode not working,
do the pictures get stored on the card? (check this with a card reader on a computer...)
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
