Question about Astra Home Grinder Electric
Astra home electric grinder
My grinder was jammed up with grinds so i took it apart and succesfully ckeaned it, but i need to get the grind back to fine. its coming out rather large right now. any tips?
    President:
  • 1,618 Answers
Turn adjustment ring towards fine, until it cannot move, then back towards coarse about 5 numbers, that should give you a good start on the grind.
Posted on May 23, 2009
I took everything apart to give it a good cleaning and now all settings produce a very fine grind. Any thoughts?
I had the same problem with too fine a grind when I took mine completely apart to clean (including the lower burr). The solution I finally came around to was to further tighten the star-shaped screw which holds the lower burr assembly in place. I had originally just tightened it until the lower burr until the lower burr assembly started to turn with the screw, but that wasn't enough. So I held the assembly in place and tightened the screw further and I'm back to my previous grind coarseness/fineness.
Jan 13, 2014 | Jura Capresso 560 Electric Burr Grinder
Myu Bodum Bistro burr grinder calibration is off. How do I fix it?
Did you ever find a solution? I have the same grinder and it is off as well now after taking it apart.
Nov 11, 2012 | Coffee Makers & Espresso Machines
My grinder is jammed How do I unjam it
what kind of grinder so you have.
if its jammed then you need to check the motor that there is no obstacle comming to the motor.
basically you have to open the grinding chamber.
BUT THEN YOU NEED TO ADJUST THE GRINDING QUALITY.IF YOU DON'T KNOW THEN DON'T DO IT
if you need help then reply me back
thanks
rate me for this
Aug 16, 2011 | Bunn Coffee Grinder
Have a grinder and it is full of coffee and stuck. It seems the beans were more oily and now I am trying to figure out how to clean it out. Please help
  • Try to grind all the beans through.
  • Put some uncooked rice inside the hopper and grind it, it is very good at cleaning if you don't have Grindz. Get Grindz if you can to grind and clean the burrs.
  • Try to take the grinder apart and brush off and clean off the burrs by hand.
Jul 13, 2011 | Bodum Antigua 5670/5671 Electric Burr...
Can not turn the grind wheel - forgot how to do it. It has been on medium grind so long, now want fine grind
Same thing happened to me. It turned out the cause was a build up of hardened coffee grounds. We took it apart (a bit tricky!) and cleaned it. Now works like new.
Mar 26, 2011 | KitchenAid A-9 Electric Burr Grinder
I took the grinder apart and realized that there is no mark as to where set the initial burr setting. It does not seem to be that you screw it down as far as it will go. the adjuster spring simply gets...
simply you screw until you hear metal sound of burrs touching each other. Than:
Grinding setting is one simple operation but requires bit patience:
  1. Turn on your grinder and continue setting to fine while burrs are spinning, you stop when you hear metal to metal touch sound(burrs maximally closed finest grinding)
  2. From that point go back quarter of revolution and mark the spot where you stopped with marker to body of grinder and setting plate with one line
  3. Grind little amount of coffee only to fill one sector of dosser than test it at your machine (if it leaks too fast and with yellow color of cream you should go to more fine>><< if it does not leak from the filter holder or it leaks very slow you go to in opposite way.
  4. You test grinding few times bit after each reset of plate grind little amount and take that in one other pot (that will provide to have pure new granulation)
After setting measure the grounded coffee that comes out from dosser it should be about 7 grams, better measurement you can get if you measure 10 doses in one place because you don't get never same amount from 6 sectors of dosser
Dec 07, 2010 | Gaggia MDF Electric Burr Grinder
I took apart my Pasquini K2 doserless grinder for a cleaning this morning and while putting it back together, the locking pin is sitting flat, as opposed to being spring loaded as before. I didn't notice a...
It does have a spring that you may have simply lost. It is called a Grinding Setting Pin #HGP120. If you do not replace the spring you will lose your grind setting each time. I can send you a replacement spring via USPS for $2.50 +$4.95 Postage
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
Feb 19, 2010 | Pasquini K2 Doserless Coffee Grinder
How do you take apart the grinder on Saeco Spidem Villa Household Coffee Machine
There should be screws on the side or the bottom of the unit that will allow you to pull it apart. The problem seems to be that the two grinding wheels have gone bad and needs to be replaced. On this unit you cannot adjust the grinding as far as would need to be to fix the problem when the teeth get to small
Jun 03, 2009 | Saeco Spidem Villa
Embarassing but...
No, wait, I found it. If it's round and is (or used to be) white, it fits on the bottom of the clear plastic hopper. Replace it and you should be in good shape again.
Jan 02, 2009 | Solis Maestro Electric Burr Grinder
Astra Home Grinder Electric Logo
133 people viewed this question
Top Astra Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ross Keen
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Astra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
