Question about Astar PD-3010 Portable DVD Player
Hook up to tv
I want to watch dvd movies on my tv, using the pd-3010 as a regular dvd plater.
  • 40 Answers
please call me at 323-767-6030 and I will go through with you.
Show you how to work on, resolve this problem.
Posted on Feb 26, 2009
I just bought a samsun 40 inch tv and I wanted to watch cd movies but I can't find dvd player, I thought all tv had them now, how can I watch cd movies, do I have to get a dvd player to hook up to the tv?
Yes, you would need a dvd player or some sort of additional media player. They have alot of different kinds out now. You can even use your cable box to order movies, or you can even use a device that will stream movies instantly such as netflix.
Mar 02, 2011 | Samsung LN26A330J LCD TV
For just over 2 yrs my Astar PD 3010 worked really well. Now it is giving me the following problems: 1) Even though the battery light flashes green it is not able to hold a charge for more than 10 mins; 2)...
You need a NEW Battery, and I also wonder if your Wall supply hasn't gone faulty too, you must swap out for a known good, i mean that;s all one can do. It does sound like your battery is definitely no good, you will have to test the adapter, with the battery removed, the PC, should work FINE, for as long as you want to use it.
May 08, 2010 | Astar PD-3010 Portable DVD Player
I found an Astar portable dvd player with only the battery charger attached months ago and nobody claimed it. I used it night before last and watched a whole movie, last night I watched a movie and it just...
Possibly you just need a new power supply/battery charger. There is nothing "magic" about the original power supply. Take the player into an electronics supply shop. They should be able to look at it and match
Voltage In Voltage Out Power requirement (milliWatts or Watts) Connector Type Polarity (center of plug positive or negative)
Oct 10, 2009 | Astar PD-3010 Portable DVD Player
Need to hook up to tv
use the colored lead (RC) cables to connect from dvd player to your tv, it is color coded so you cant go wrong, then select av on the tv to watch dvd, if it can connect to tv with rc cable then you will need an adapter to connect dvd through antenna jack ok
Jun 29, 2009 | Protron PD-007 DVD Player
Have ASTAR PD 3010 PORTABLE DVD PLAYER - NEED REGION CODE
Properties like region are built in features. Keep that region setting to "0". Remember u can change it only 5 times, after that it stays locked in the last entered region!...sodeep
Jun 20, 2009 | Astar PD-3010 Portable DVD Player
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
I have a vhs and dvd player all in one
I have a converter box hooked up to my tv and vcr , dvd player combined
I can play my movies on the tv. ok.
you have to have your tv and vcr set on channel 3. if that is what your main tv is set up with. Or 4 if you have your tv set up with that.
Mine plays ok. My settings are for channel 3
My suggestion would be to check your hook ups. maybe they are not hooked up correctly
I had to go to www.google.com and did searches to help with hook up.
I can also record station I am watching with vcr on vsh tapes. I do not have a dvd recorder.
I found out that you have to have 2 converter boxes hooked to one tv., in order to record on on station while watching another. I have not tried that, as I don't have 2 converter boxes for one tv. I found that by doing google search also. Good Luck
Dec 04, 2008 | Televison & Video
Desire Audio for Theater System when watching Tv.
hi there
you can hook it up to your tv and make your regular shows sound like theaters too. all you have to do is check with your tv menu and look for a setting there which is similar to hall,theater...etc. not all audio settings has this though.
hope this helps.
Feb 11, 2008 | Audio Players & Recorders
CONNECTING A VCR RECORDER/PLAYER TO A HD FLAT SCREEN TV
Now one question - Do you want to record the TV program on the VCR or Movies from a DVD plater hooked to your HD TV?
Jan 10, 2008 | Goldstar GVR-E435 VHS VCR
No disc
When the Astar PD-3010 or the PD-3020 shows no disk it mean that your DVD laser are defectived. Need resolve this problem? Please call me at 323-767-6030.
Dec 26, 2007 | Astar PD-3010 Portable DVD Player
Astar PD-3010 Portable DVD Player Logo
82 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
