Question about Bosch Axxis WTA 3510 Electric Dryer
Our Bosch Axxis WTA3510US/10 does not start any type of cycle when we press the start button. The control panel appear to respond to cycle setup commands including number of cycles, type etc... But when we press the start button, nothing happens. Do you have any suggestion? Thank you in advance.
2 Suggested Answers
  • 16 Answers
SOURCE: Bosch wta3510us tumbling NOT heating. Reset button?
Remove your back cover ,and then you see the heating element.On one side or on top there is a termostat(Small Black)there is a red button which you should press down until you hear a click.Start machine and element should work.You can start it for a little while but be careful.Put cover back after cleaning loose lint etc. Jan
Posted on Feb 13, 2009
When The door is open continues to run on my Bosch Axxis Clithes Dryer WTA3510US
the door switch contacts are welded together,normally it switches when the door is opened to light the interior drumm light and to the dryer circuit when the door is closed,but these contacts cant due to being stuck
Nov 15, 2012 | Bosch Axxis WTA 3510 Electric Dryer
How do I set the date?
Follow the instructions below to set date and time on your printer.
  1. On the product control panel, press Setup (c01715732.gif ).
  2. Press the Left (c01185108.jpg ) or Right (c01185072.jpg ) Arrow button to select Basic Setting , and then press OK .
  3. Press the Left (c01185108.jpg ) or Right (c01185072.jpg ) Arrow button to select Date and Time , and then press OK .
  4. After Enter date appears on the control panel display, use the keypad on the control panel to type the date in the correct two-digit format, MM-DD-YY (01-01-10). After entering the date, press OK .
  5. After Enter time appears on the control panel display, use the keypad on the control panel to type the time in the correct two-digit format, HH:MM (10:15), and then press the Right (c01185072.jpg ) Arrow button to switch between AM and PM . After entering the time, press OK .
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 29, 2010 | HP OfficeJet J4580 All-In-One Laser...
My new bosch axxis washer was20160uc does not start
Open the dishwasher door if the desired cycle does not perform as selected on the control panel. Press the main power switch "Off" and then "On" again. Select a cycle, press the appropriate button, press "Start" and close the door. Make sure the door is closed completely.
Check the circuit breaker and water supply if the dishwasher does not start after selecting the appropriate cycle on the control panel and shutting the door.
Turn "Off" the dishwasher and disconnect the dishwasher from the power supply if an error code between "E01" and "E30" appears on the digital display. Reconnect and turn the dishwasher "On." This should reset the control panel.
Terminate a program on the control panel by holding the "A" button and pressing "Start" at the same time. The display will read "0:01". Close the door to start the program sequence. The display will read "0:00" when finished.
Oct 15, 2010 | Dishwashers
Bosch axiss dryer WTA3510US wont run checked power, fuses. i close the door hit start the drying light comes on but nothing happens no clicks noies's nothing. is it the relay board or somthing else?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 14, 2010 | Bosch Axxis WTA 3510 Electric Dryer
How do i deactivate the child lock on the bosch axxis washer
Hi
To unlock the washer press and hold 'dry' & 'spin' button. It should unlock now. If this doesn't work then press and hold "end of cycle" button for 5-10 seconds. However, if it is still locked then unplug the washer for 5 minutes and then plug it back. After plugging it back press and hold Start button for 10 seconds to unlock it. Hope this helps...
Daniel
Aug 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Can't open the door on a bosch washer. tried running it thur another cycle, still will not open.
The safety lock is probably on. Press and hold the 'start/pause' button until it clicks.
Nov 11, 2009 | Bosch Axxis WFL 2060 Front Load Washer
When I start my Bosch Axxis machine - I purchased it used - I do not hear the water start and the cycle isn't starting.
When you close door properly and press start does the door latch? If not possibly the latch is the problem. If it doesnt give a normally closed condition, the micro processor wont continue.
Sep 21, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Jan 09, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Setting date and time on HP office jet J4580
Set the date and time
    press OK .
    press OK .
  4. After Enter
    date
  5. After Enter
    time
Aug 21, 2008 | HP Office Equipment & Supplies
Can't deactivate child lock on washer
Try: Press and hold 'dry' & 'spin', shd unlock OR
Try holding the "end of cycle" button down for 5 or 6 seconds. You must hv done it accidently, it is the child lock device. Pl. rate if helped.
Jan 04, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WTA 3510 Electric Dryer Logo
111 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
