Question about Whirlpool Duet GHW9150P Front Load Washer
Where can I get Scalegon, the scale removing powder?
Why is it leaking during operation?
Could need de-scaling. Scale builds up after time and reduces flow rates, increasing pressure leading to leaks. Give it a go with any generic de-scaling powder or liquid following the instructions. My coffee machine (different model) did similar and now works like new again.
Aug 26, 2015 | DeLonghi ECO 310.BK Pump Espresso Maker...
How do I clean up the washer after a long time wash
Use the scalegon powder or white vineger 200 ml to clean the tub put tub clean program it will works auomatically, dont put clothes
Mar 01, 2015 | LG WM0642HW 4.0 cu. ft. Front Load Washer...
My willows r shedding and have a white powder substance on the branches what to do?
Not enough info. White powder could explain a scale or a fungus. Did you mean shedding? Willows prone to aphid. If these are the problem treat root system according to label with Merit (Bayer) also known as imidicloprid.
Jul 26, 2014 | Garden
My Bosch dishwasher is failing to clean anything and there's guck and residue on everything. I've cleaned the filter repeatedly to no avail. HELP!
It needs a thorough cleaning, the "guck" is your problem. Do not use liquid, it will make it worse. The "squares" are also detrimental. BOSCH engineered this machine to function best using loose powder. Remove all screens and use a calcium or lime scale remover with water very very hot, like from a coffee pot and run it empty a few times.
Aug 26, 2012 | Bosch 24 in. SHU43 Built-in Dishwasher
Where is buy scalegon cleaning powder for whirlpoorwashing machine
We Will Deliver The SCalegon Powder. FREE SHIPPING>JUST FOR 100 RS only `Interested Pls CAll 9962222287
Jul 18, 2012 | Whirlpool Duet GHW9150P Front Load Washer
What would make my dishwasher leave a white powdery substance on the dishes?
The white film or powder can be caused by a couple things. Due to environmental laws, phosphates have been almost entirely removed from DW detergent. Phosphates were effective at preventing this. Also scale buildup on screens and in the pump can reduce the amount of water being pumped around. Use less detergent, try half filling the cups. In addition to the detergent put 1/4 to 1/2 cup of citric acid in the dishwasher and running a load. This will remove scale buildup. I use it about every other day. You can buy citric acid online, I bought it at thechemistrystore.com
Nov 12, 2010 | GE Nautilus 24" Built-in Dishwasher
I need cleaning instructions
I used an air-compressor with a small soft rubber nozzle, and blew out the rubber over-fill port, the peircing needle and the reserviour inlet, and it started working like new. I have done this to two seperate machines - that were both having short-pour options, and it worked like a champ
Nov 07, 2009 | Keurig B60 Coffee Maker
Top loader washing machine no drianing water
run the machine with a lime scale and detergent remover such as soda crystals on a boil wash no clothes or powder .
what happens is the powder or detergent if u use to much i does not disolve properley and gunks up the pump and filters they have a detergent and limescale remover on espares
Jun 28, 2009 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
592 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
