Question about Vizio Televison & Video
I have a vx37L vizio that will no longer get or scan for digital channels
  • 6 more comments
  • rcmia Sep 17, 2010
    yes I still get all the analog channels just fine,also channel up-down on my remote stopped working at same time as the digital channels stopped working.
    please is there any way to determine what the problem is??
    can you provide me with a part number for tuner board??
    can you provide with a part number??
    do you know the part number for a VX37L ??
    could you provide main signal board for VX37L 37" Lcd tv??
  • rcmia Sep 18, 2010
    Thanks I will check back with you tomorrow
    i dont use set top box but will newer DVD player work?
  • 10,515 Answers
I believe the problem will be a bad control circuit in the TV. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment.
If you have electronics repair experience, could read schematics and would be able to take all precautions, revert and i would be able to tell you where you could purchase service manual and would provide you few pointers that would help you to resolve the problem.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 18, 2010
  • 5,807 Answers
There are only two possible reason hardware failure or
hardware settings .
Your hardware can be found here :
Vizio 3637-0042-0395
http://www.encompassparts.com/products/?3637-0042-0395#
It could be from Regulator Circuits or from the
IC s itself,
Another alternative is to use a separate tuner, like
a set top box or from a VCR , and use your TV as a monitor
by connecting cables for Audio and Video IN.
  • Vizio Master
  • 12,061 Answers
Hi, well First you must check to see if the antenna system is 100% A OK. As if this isn't then there is no way for the set to acquire a signal.
Now if you have checked it all out, and all is OK, that's the Plug, (make sure it is making good contact in the female socket) the Signal Amplifier, the Cable and the Antenna itself, the best way to check, is to try another unit on that antenna, or conversely, try your set on another antenna. So if you find you DO have a signal and it is all OK, then most likely your set has a Power Supply problem to the Tuner, or the Tuner is faulty. Either way you need to have this unit looked at by a professional, as most likely again, if it is the Tuner it will have to be replaced and then all re-set up again.
Should you wish to DIY, I have included all manuals for your convenience.
pctechsva.com/Documents/VIZIO_VX37L%20HDTV.pdf -
Above is a copy of your service and repair manual, below is your user manual, BOTH are critical. If you wish to DIY. http://www.retrevo.com/support/Vizio-VX37L-TVs-manual/id/3068ag225/t/2/
Use these manuals to troubleshoot and isolate your issue, with a view to a repair. In any even, if you download and print these manuals out, and give them to the service people, this will only aid in the speed up of the repairs.
  • Vizio Master
  • 5,138 Answers
You need to replace the main board, which is also called signal board.Encompass Parts Distribution might have it in stock
1-800-638-3328 Its the board that has your tuner and AV/ jacks on.
Posted on Sep 17, 2010
    President:
  • 2,777 Answers
Does it still receive analog channels then? So when you manually try to go to channel "45" for example, what does it do?
Thanks, let me know and I can help
Tim
  • 6 more comments
  • Tim Grayson
    Tim Grayson Sep 17, 2010
    Can you manually input a channel? Does channel up / down work via the button the TV?
    Thanks
    Tim
    yes I can manually input channels, I am not where my tv is at this time so I do not know if button on tv changes channels-I asume so
  • Tim Grayson
    You don't know where the TV is? That will make it very difficult to fix. It sounds like the remote itself may be the problem...
    yes I know where tv is, it is at my business and I am at home at this moment. I dont think it is the remote because when I brought my remote home it works perfectly on my 42" vizio(channel up and down included)
  • Tim Grayson
    Ah ok, that's a good test, and if it works at your home then you are correct, it is not the remote. However it may be the remote receiver on the TV that has the issue. If you are able to change channels up and down on the TV itself, but not the remote this would definitely indicate the remote receiver is having some problems. It may not be the only problems though... if it unable to change channels to a digital channel manually, then there is some kind of hardware failure going on inside this TV. It is very cost prohibitive to repair a TV like this one...
    Let me know what you find..
    Tim
    I dont think it could be remote reciever as all other function on remote wirk fine. I would like to find out if it is the tuner board or something like that. Some of those parts like tuner board are available used on ebay at a very reasonable price.
  • Tim Grayson
    It probably is the tuner board having problems, and you can replace that and it should be able to receive the digital channels again. If you are extremely technical and feel comfortable taking apart a TV and re-soldering things I would suggest you go ahead and get a tuner board and replace it.
    i am sorry i didnt see your reply to my last question(collapse menu) my apologies
32in Vizio getting no channels
You have to go to your menu screen and change the settings from antenna to cable that should take care of it, and should be able to do a auto scan to load channel memory
Mar 26, 2013 | Vizio VX37L Television
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
No digital channels after running auto search
Same thing with my vizio vx37l tv. Did you fix the problem bpakja? If so please let me know how.
Sep 30, 2009 | Vizio VX37L Television
Auto search through
Tested and verified solution:
  1. Set Tuner Mode to "antenna".
  2. Run a channel scan. Should get zero channels found.
  3. Set Tuner Mode to "cable".
  4. Run another channel scan.
  5. Celebrate!
Aug 16, 2009 | Vizio VX37L Television
Black screen on digital channel on my vizio
I had the same problem. Check out my solution by viewing the subject titled Vizio 37L suddenly stopped getting all digital... Hope it helps!
Jun 20, 2009 | Vizio VX37L Television
Sudden no signal on digital channels on a Vizio VX37L
That may not be correct. You would not lose all your digital channels. Vizio has an un-addressed problem with losing digital stations. Multiple threads are posted due to this problem, which is why I am on this site. I have lost all digital stations on CATV connection. The Toshiba set in the next room is getting over 150 DTV channels, the Vizio, only analog. Zero Digital.
May 23, 2009 | Vizio VX37L Television
Sound and picture interference when changing channels from hd to regular tv model VX37L vizio
It may be the cables you are using. You will need to HDMI cables for high def and rca or coaxil for regular
May 09, 2009 | Vizio VX37L Television
Comcast 3 in 1 Remote code for Vizio VX37L television
The codes are:
10864
10885
11756
11758
10178
11017
10030
11265
10178
10700
10856
11178 - this one worked for mine
11993
Dec 30, 2008 | Vizio VX37L Television
Channel buttons (up/down arrows)
Do an autosearch in the setup menu and that should program those buttons. Weird I know, but it worked for ours!
Apr 14, 2008 | Vizio VX37L Television
Televison & Video Logo
173 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
