Question about Whirlpool GBD307PDS Electric Double Oven
We have a Whirpool Gold Double Oven Model # GBD307PD9/XR011095 purchased January 5/05. We have had this unit serviced several times for a malfunction. When both ovens are on they reach temperature (350 degrees) and immediately shut down and we get a PF on the LCD. We've had the main circuit board changed and the service man has taken the unit apart and checked everything (according to him). It works fine for a while but the problem keeps coming back. We seem to be able to use the upper oven alone but not the two at the same time. Have you had similar problems with this type of oven? We have the service man coming in again and I'd like to give him your feedback.
    Brigadier General:
  • 3,917 Answers
I just moved into a new apartment, I can't find the user guide for the whirlpool gold gas oven, don't know how to operate the oven, none of the button works on the control panel, not even the start...
You can go to whirpool.com then click on owner center and download a manual BUT YOU MUST HAVE COMPLETE model number which usually on inside of oven door or in storage drawer
Jul 27, 2011 | Ovens
Whirpool Electric Double Oven
1-800-269-2609 call them and they can www.repairclinic.com
Dec 23, 2007 | Ovens
Whirlpool Gold double oven - started beeping then all lights on the control panel went out. Reset the circuit breaker which makes the oven beep but still have no lights. Oven will not operate.
I was just looking over a manual for a late model double oven. Their is a thermal limit going into the controls that will open if the temp rises enough to harm the controls. They look like this one.2605a73.jpg That kills all power to the control and you will see nothing on the display.
This manual will give an idea where to look:
Late model double oven
Sep 27, 2010 | Whirlpool GBD307PDS Electric Double Oven
Double oven, top oven run by keypad turns off
I have a double oven. The top unit works fine. The bottle unit will turn on to cook or clean. Then after a few seconds it turns itself off.
Oct 12, 2009 | GE Profile JKP56 Electric Double Oven
We tried using the self clean on our Whirlpool Gold Accubake Duo system range. It locked the oven door and gave code e1 f5. We disconnected the power and turned back on to the same codes. HELP!!!!!!
take the trim peices off. take the screws that hold it to the wall out slidee unit out a little to remove the 2 screws from the consol lift the consol up and off. make sure that you have turned the power off inside the unit you will see a tech sheet that will tell you what that error code means. let me know how it goes the tech sheet is usually on the left side.
Jun 16, 2009 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool Gold Series double oven electric model GBD307-PDQ309
Usually this is a touchpad and control panel fault but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
With the model number of the oven we could look up the code and be more specific about the problem.
Go here for: http://www.repairclinic.com/Whirlpool-Range-Stove-Oven-Parts
RepairClinic.com
asplogo.jpg?ver=23
appliance parts, help & more
Apr 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool Double Oven RBD305 Display doesn't show, oven wont work
Most definitely a bad control board and/or soldered components. (The part about cutting power to the oven was a dead giveaway)
There are low and high temperature solders, but usually solder melts at 370° F. If the oven is improperly insulated or ventilated you will have continued heat stress to the control board.
Mar 31, 2017 | Whirlpool RBD305PD Electric Double Oven
I have a double gas oven and no instructions
I have an O'Keefe & Merritt double oven gas stove. The model number is 72 7242 23. The upper oven is about the size of a large microwave and sits above the range burners. The lower (full-size) oven is below the burner unit and includes a broiler draw below it.
So, when you say, double oven, I wonder if you are just talking about the main oven with broiler drawer (both of which are below the burner unit.)
Mine was a builder-supplied appliance in the new house we purchased in 1986. The upper oven has never performed very well. And, yes the upper oven can only be used for baking.
I have an instruction manual for it, but it doesn't provide that much information. Getting parts for it is extremely difficult, since Tappan is no longer manufacturing this brand. (I've been trying to locate a flat oven ignitor for the upper oven and can't seem to find a replacement that's the same 6-1/3" length.) In the 1980s Tappan apparently purchased O'Keefe & Merritt and marketed this brand for several years. Models originally manufactured by O'Keefe & Merritt in the 1930s-1950s are considered collectible antique stoves!
If you want to email me, I'm at oldvic@erols.com
Apr 20, 2008 | Stoves Premier 900GRa Gas Double Oven
Oven Stops Heating
try it on broil and let me know what it does i dont think its a sensor as they check their selves and set a code most of the time
Feb 15, 2008 | Ovens
Whirlpool GBD307PDS Electric Double Oven Logo
82 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
