Question about GE Spacemaker WSLP1100D Top Load Washer
HELLO, WSL100D0WW IS MAKING NOISE ON DRAIN/SPIN CYCLE.
WASHING MACHING IS MAKING A NOISE ON DRAIN/SPIN CYCLE LIKE SOMTHING IS LOOSE IN IT (RATTLING/SLAPPING/LOOSE OBJECT SOUNDING NOISE). NEED HELP BEFORE TAKING APART. ADVISE PLEASE...
  • Anonymous Mar 14, 2014
    washer will loose power all on its own. you can unplug for couple min then plug back in and wash complete cycle. then washer will loose power again. the washer will loose power even if you don t use it after reseting it
  • 5 Answers
Or, you have coins in your pump casing. Look on the back of the washer, and unscrew the circular port in the bottom right corner. (Keep an 8x13 baking pan underneath, water will escape once you open the chamber). Remove and change/objects from the chamber and replace the port. You should be good to go. This is actually very common for this model washer.
Posted on Jun 19, 2008
  • 38 Answers
There is a bolt that is broken on the agitator shaft. lift lid, take off centre piece at top of agitator, lift out plastic seal, lift agitator out. replace the two horizontal bolts holding drum to shaft. tighten all the way.
Posted on Jun 01, 2008
Electrolux front load washing machine ew10001 spin cycle slow on "SPIN" setting runs fine through regular wash setting? any ideas?
Hello jamespeattie - Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Jan 02, 2013 | Electrolux EW1000i Front Load Washer
Will not spin
Hello - Is the drain pump making a humming noise? If so, you possibly have a restriction in the drain line. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Contact a professional to move forward accurately.
Jan 01, 2013 | Frigidaire FEX831CS Top Load Stacked...
Glws1339cs1, started making noise like a belt was slipping during the spin cycle
Hello Bill Johnson - Is the washer draining or spinning? Could it possibly be a humming noise? If it is not doing either or and making a humming noise then it could possibly have a restriction in the drain line. Or either the belt is loose and will have to be put around the transmission and then spin it on to the motor or there is an issue with the lower/upper bearing. I would suggest contacting a professional to move forward accurately to properly diagnose/repair the washer.
Nov 12, 2012 | Frigidaire GLWS1339C 3.0 Cu. Ft. Top...
Hotpoint washing maching making a loud noise on spin how to get in to it
see this possibles causes:
During fill only
air gap device, crack see the diagram+tube can be crack+inlet spout break.
During drain and spin only
check the hose, allternative the outer tub
All the time: main tub +pump+outer tub defective replace
see the diagram
Jun 18, 2012 | Bosch Washing Machines
Whirlpool ETW4100SQ washer. Unit stopped agitating, grinding noise appeared. Tub is loose, agitator is free, was able to empty the drum.
while your washer will draining, in addation to the noise during the agitate cycle is it making a similar noise during the drain/spin cycle?
if that is the case the motor coupler is broken
i have attached a youtube video that will show you step by step how to replace the coupler
http://youtu.be/9K1KHEogf3c
the part number indicated in that video is the exact part number for the coupler
GOOD LUCK,
GENE
Jul 26, 2011 | Washing Machines
Admiral makes rattling noise during spin
Hello, could be a possible bad pump. I would lean the washer back so you can see the belt. take the belt off and spin all of the pulleys. the pump pulley has a s leave that sometimes makes a grinding noise.
Jan 05, 2009 | Admiral AAV7000A
Washing maching
replace the motor coupler...you have to remove the case and then the water pump, then the motor....the coupler in behind the motor
Sep 16, 2008 | KitchenAid KAWS850L Top Load Washer
Whirlpool Washer won't drain or spin
check the lid switch operation,not sure what the noise could be maybe somthing stuck in the pump? hope ths helps unless the contacts in the timer are faulty i have opened up a few timers and fixed the contacts short term.
Mar 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle trouble
possibly a segment has raised on the motor armature or a faulty motor brush. pop off the belt and put it into a spin cycle to see if you still hear the noise- if so the fault is with the motor as the drum will be still. any scraping sounds in the drum may be a lost bra wire.
Jun 03, 2007 | Asko W640
GE Spacemaker WSLP1100D Top Load Washer Logo
767 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
