Question about Bosch & Tankless LP Hot Water Heater
There seems to be a flow problem. The pressure starts out fine and ends up a trickle but only on the hot side. I have used the T & P valve to try and back flush the unit , to no avail
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
In order to clean the unit you need to connect a small sump pump to the cold inlet, and run a hose from the hot side into the same bucket. Pour about a gallon a white distilled vinegar in the bucket, and turn the pump on. Let the solution run through the unit for about 15 minutes, then reverse the hose connections and run the pump for another 15 minutes. Reconnect the water supply and outlet. Turn the water on in the bathtub first on the hot side and let ir run for a few minutes before turning the power back on to the heater. While the water is still running turn the power back on and reset the thermostat. If you get a lot of debris in the bucket, you may need to consider installing a water-softener to prevent scaling.
Posted on Sep 17, 2010
HOW DO I UNFREEZE MY WATER HEATER I HAVE KEPT THE DOOR OPEN AND A SMALL HEATER IN FRONT OF IT BUT IT MAKES NOISE BUT NO WATER FLOW YET
it is probably not the water heater that is frozen but pipes in the area. Close the door leave the electric heater on and open a valve to let water trickle when it starts to flow.feel the pipe on the hot side of the heater if it is warm it is not the heater. try to stop any drafts and you can use a hairdryer to try to warm pipes that you think might be frozen. a torch will also work if you know how to use one and avoid any flammable areas.
Jan 17, 2015 | Water Water Heaters
I have a Vaillant Combi boiler, recently serviced by British Gas, given all clear. Problem we are having is the downstairs hot water tap it is a mixer tap, the cold water is fine but the hot water is
Boilers are inherently dangerous for the average DIY for so many reasons, contact British Gas and have them come back and fix it, tell them it was fine before the "service". They may simply have a control valve shut off.
Sep 23, 2014 | Water Heaters
2010 view winn- the hot water faucets, when wide open the flow is very slow-light flow. The hot water heater has never been used. I have filled it and drain it, there was no trash in it. I refilled it and...
Double check that washers inside fittings attached to back of tank, are not wedged or pinched in there restricting flow. Drain tank, relieve water pressure prior, obviously. The other thing is to check that the by-pass is allowing good flow in to tank when in normal operation mode. Have seen those only go half way inside valve, but lever is at wide open setting. If all that checks out, try removing the check valve on tank, and replace it with a 1/2" galvanized pipe nipple, ( or certified plastic/nylon fitting same size) and reconnect water line direct to that, without a check valve. That should do it if nothing else was wrong. Now you have a choice, either change it or leave it out if everything seems ok, but double check that hot water isn't siphoning back to another utility such as toilet if you leave it out and toilet is close. Feeling that cold line (inlet) when water is hot should tell you. I've seen the check valve in both locations, hot (at top of tank) and cold (at bottom of tank -inlet) Not 100% sure why, right from factory that way, but I say, put it on bottom fitting if required at all. Let me know how you make out.
Oct 20, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
No water pressure
Check all valves are open, cold in bottom, pushes hot out top, and if cold at tap is doing same, take aerator off tap and see what happens. Is same thing happening at all taps?
Apr 25, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water Heater Keeps Going Off
is there a check valvle on hot water side of heater,a flow restriction of some sort, water pressure to the heater, a filter in the line, line pressure in the heater kicks out burner, when you turn on the water, line pressure drops, heater comes on, when you turn on water in other part of house, heater should not fire, so there has to be a check valve somewhere,in heater?
Jan 24, 2010 | Noritz 6.9 Gallon Residential Tankless...
The hot water just trickles out of the hot water taps, I've checked & cleaned the tempering valves, mains water pressure is fine, is the cylinder scaled or blocked
Something is blocked. Turn off water to heater disconnect outlet and attach a waterheater flex connector to tank outlet bend other end into bucket. turn on water briefly - water should blast into bucket.
If not:>>>>>>>>>> disconnect water heater inlet -you may find part of the flex washer stuck into the inlet nipple. Or dip tube may have disintegrated and be plugging outlet nipple, if you have the energy saving nipples the ball can jam debris in the nipple.
If water does blast into bucket >>>>>>>>>>>> Then the problem is farther down the line, maybe bad mixing valve. disconnect mixing valve outlet and use a garden hose to backflush through mixing valve with bucket under hot pipe disconnected from water heater. If flow through valve is restricted, replace valve.
Jan 01, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water flow is reduced to a trickle after only 2 mos. of use with the quick&heat water heater. we are in San Diego and water is nit that hard. Lawrence
Lawrence; there are several potential points that can reduce your water flow. Try these items and let me know. Check hoses under sink for any kinks.......take the aerator off the faucet and run water if trickle is still there then aerator is fine......check the valve that the water comes from and make sure it is turned all the way on. If these do not solve your problem let me know. Thx
Aug 04, 2009 | RTO Waste King AH-780-UL Quick&Hot Instant...
Hot water taps and showers pressure very low cold taps ok
there is a little cap on the hot and cold side above the shut off valves, turn the water off at these valve and take the caps off there are filters in there clean them off and reinstall them that should take care of the problem, you might want to flush the tank while your at it hook a hose to the hot side connector and run it out side or to a sump pump then turn on the cold water and flush it out you can also reverse this procedure by doing it on the cold side
May 24, 2009 | Rheem Tankless water heater for 1-2...
A trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
May 18, 2009 | Water Heaters
Bosch & Tankless LP Hot Water Heater  Logo
73 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
