Question about Sport & Outdoor - Others
I have a thigh trainer from 2003, the brochure has a "lock up " solution but won't work with my problem. Both pedals are in the down position, not locked, and can be lifted to the top in the up position. Both pedals are loose.
    President:
  • 2,777 Answers
Hmm, it sounds like something mechanical in the inner portion of the trainer... Do you think it is just a couple loose bolts / screws? It is hard to tell without seeing it in person... this is a very difficult "remote" repair..
Let me know a bit more about it and I can help
Tim
Posted on Sep 17, 2010
My lateral thigh trainer is stuck in one position and won't move when stood on.How can I loosen it?
Eat more Big Mac Meals and drink more beer. The resulting weight gain might break the tensioner loose. Also take the trainer tension adjuster apart, clean and lubricate it just a bit.
Apr 01, 2016 | Cars & Trucks
My 2003 lincoln aviator key won't turn
Try looking at the Brake lights when the brakes are pressed. There is a switch on some of the brake pedal levers that sends a signal to release a Lock-out for the Ignition.
If the brake lights do not work, the brake lever switch is out of position or broken.
This is a common problem with many Ford designs and occurs when the drivers feet hit the switch.
Mar 16, 2013 | 2003 Lincoln Aviator
In what way is an elliptical trainer different from a treadmill?
Treadmills have a moving belt while elliptical trainers have two foot pedals guiding movement - making it more controlled and safer. Elliptical trainers also have handles, in which the user has the option to move their arms in opposition to their legs to better control movement.
Aug 02, 2012 | Exercise & Fitness
Why won't 2003 pontiac grand prix. shifter come out of park?
Shift - interlock system problem .
Automatic Transmission Shift Lock Control System
The automatic transmission shift lock control system is a safety device that prevents an inadvertent shift out of PARK when the engine is running. The driver must press the brake pedal before moving the shift lever out of PARK position. The system consists of the following components:
• The automatic transmission shift lock control solenoid
• The automatic transmission park lock solenoid
• The automatic transmission shift lock control switch
• The transmission range switch
With the ignition in the ON position, battery voltage is supplied to the automatic transmission shift lock control switch. The circuit continues through the normally-closed switch to the automatic transmission shift lock control solenoid. The transmission range switch provides a path to ground for the automatic transmission shift lock control solenoid in the PARK position. With the automatic transmission shift lock control solenoid energized the shift lever is mechanically locked in the PARK position. When the driver presses the brake pedal, the contacts in the automatic transmission shift lock control switch open, de-energizing the automatic transmission shift lock control solenoid. This allows the shift lever to move from the PARK position. When the shift lever is out of the PARK position the controlled ground contacts in the transmission range switch open. This prevents the automatic transmission shift lock solenoid from energizing when the vehicle is out of the PARK position.
Jul 04, 2017 | Pontiac Grand Prix Cars & Trucks
HOW TO REMOVE BATTERY FROM LATERAL THIGH TRAINER
It's in the Right Foot Pedal.  Under the right foot pedal is a "Computer Compartment" the battery is there: 1 AAA battery, should do it.
Link to the Manufacturer Owner's Manual.  You'll find battery installation under: "Assembly" (section 6).
Thank You For Choosing FixYa~!
Mar 17, 2011 | Computers & Internet
Excursion limited edition. Brake lights stay on.
Check that the pedal height isn't sagging due to low brake fluid level. Also check for adjustment of the brake light switch or the BPP (Brake Pedal Position) switch.
Brake Pedal Position (BPP) Switch Removal & Installation To Remove:
  1. Disconnect battery negative cable.
  2. Disconnect brake pedal position (BPP) switch electrical connector.
  3. Remove self locking pin.
  4. Remove switch from brake master cylinder push rod.
  5. Remove push rod spacer.
  6. Remove push rod bushing.
To Install:
  1. Install push rod bushing.
  2. Install push rod spacer.
  3. Install switch to brake master cylinder push rod.
  4. Install self locking pin.
  5. Connect electrical connector.
  6. Connect battery negative cable.
Jan 25, 2011 | 2003 Ford Excursion
How to use the Proform 515S EKG Elliptical?
To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
Jun 02, 2010 | Proform Exercise & Fitness
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
