Question about HP OfficeJet 6110 All-In-One InkJet Printer
Loaded new cartridge pressed enter for alignement keeps faIing have reinserted cartridges many times
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
You have pure printing
check expire date on cartrigdes
try cleaning cartridges via your printers menu
if nothing is happen replace them
hope i help you
if i did pls vote me
Posted on Nov 01, 2010
How to change ink cart. in hp psc 2210 all in one printer
  1. Turn on the unit, then open the print cartridge access door. The print carriage moves to the center of the unit. Never attempt to move the carriage by hand.
  2. Press down lightly on the top of the ink cartridge latch and pull the lower section of the latch out to release the cartridge.
  3. Pull the cartridge out of its holder.
  4. Carefully remove the protective tape from the new cartridge.
  5. Reinsert the new cartridge into the carriage at a slight angle. When the cartridge is fully inserted into the carriage, rock it upright.
  6. Hold the hinged flap of the latch out while lowering the latch.
  7. When the latch is fully lowered release the hinged flap. It should catch under the tabs on carriage.
  8. Close the cartridge access door.
  9. The LCD display may indicate the cartridges need to be aligned. Load paper and press "Enter" on the front panel.Discard the alignment pages that print.
Feb 01, 2011 | Office Equipment & Supplies
HP 5510: "Press OK to print Align Page" appears permanently, even after performing the alignment. Fixya advised removing power to reset the printer, but that doesn't help. I removed and reinserted ink...
To simply bypass alignment, do the following:
Press and hold the Setup button.
Press the Up Arrow button. The printer should be ready to print.
If print quality is unacceptable after bypassing alignment, troubleshoot the problem as follows:
Make sure the printer is loaded with clean, unused, white paper. If the paper is not feeding properly, check the paper path. Click here to see how.
Remove and inspect the cartridges. Click here for instructions. If the cartridges are new, make sure the protective tape covering the nozzles has been removed.
Reinsert the cartridges into the printer. Press Enter to align the cartridges again if prompted.
If the problem continues, check the cartridge ink levels. Click here to see how. Both cartridges must have ink in them for successful alignment, so replace empty cartridges.
Watch the area inside the front of the printer as the alignment procedure runs. You should see a blue light below the cartridges as they move back and forth. If you do not see the blue light, click the link at the top of this page to contact HP. The printer needs to be serviced.
Compare the alignment page produced by the printer to the illustration below. If any of the colors are missing, run the Clean Print Cartridges utility. Click here for instructions.
Abbildung 1: Alignment page
If the problem continues, clean the contacts. Click here to see how.
If none of the steps above solve the problem, replace the cartridges or have the printer serviced. Click here to see how to decide whether to replace the cartridges or service the printer.
Let us know if that was helpful,
Thanks
Shiv.
Aug 23, 2009 | HP Officejet 5510 All-In-One Thermal...
Press enter to align cartridges message comes into the window of my HP combo machine and won't change. I reset the cartridges in their holders, turned machine off/on, no go. The machine still prints out...
You should load paper and press enter to align, The message will keep coming back until you let it do alignment or press enter and option buttons at the same time.
Jul 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
Cartridge alignment
Put a teeny tiny bit of oil (3 in one on fingertip) all over the slide (chrome bar that you see looking into the printer from the front) and retry. Just a thin film, NOT enough to drip.
The self test and align 'scan and print' procedure is timing out.
Mar 27, 2009 | HP PSC 2175 All-In-One InkJet Printer
Align cartridges error
This means one of the cartridges is defective, they cant align if they cant print.  What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center.  When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in.  I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black.
Basically you align the cartridges and then swap them so the printer thinks they are still aligned.
The color still doesnt work and it is probably a defective color cartridge.
Sep 04, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Put in a new cartridge
i don't have driver
i want to load driver printer hp psc2210
Apr 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
Align page message
I have an OfficeJet 5780 and I have to do the alignment also. The allignment page it prints should have instructions on it. Just put it in the scanner and press "Enter". It needs to scan it to align the print heads.
This is from the manual on their website:
The HP Officejet prompts you to align cartridges every time you install or
replace a print cartridge. Aligning the cartridges ensures high-quality output.
To align the print cartridges when prompted:
1 Press Enter on the front panel.
An align cartridges (test pattern) page prints.
2 Load the align cartridges page face down in the ADF between the paperwidth
guides and press the Enter button again.
3 Recycle or discard the page.
Geno
Feb 21, 2008 | HP Officejet 4110 All-In-One InkJet...
Please try this http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00657&cc=us&lc=en&dlc=en&product=60259&dlc=en&lang=en You may also be able to bypass this messgage by following the instructions on this link. Further, please check if the cartridges you are replacing are the correct ones.
Mar 01, 2007 | HP PSC 950 All-In-One InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
