Check the breaker panel. See if the oven tripped a breaker.
Check
to see if power is getting to the range/oven. Does anything turn
o, -even a light? If not, check for a blown fuse or tripped circuit
breaker. Often
the main wiring connection from the house, at the range/oven, gets
burned and so breaks the connection. Then you may have to replace the
power cord to the range/oven, and the terminal block that the wire is
attached to.
Take care.
I think you may have run out of gas, since the pilot did not work while trying to use match, it is possible the gas is not supplying or you have run out of gas, you will need to check the valve to ensure there are no blockage incase you have not run out of gas, the problem could be blockage on the hose .
check the control panel that whether it works properly or not..the heater...
hope this has helped you,,,
Thanks,...
I have no power for the oven at all.
The electricity on the range is not working, though it is everywhere else. Did light pilot on stove by match. Didn't impact anything else and I have people coming over for dinner tonight! Thanks
None of the electricity on Kenmore 790 is working; switch panel is fine, elec. everywhere else is fine. Manually lit the pilot light so I can cook on the range. Nothing functions on the panel. Thanks I have a dinner party coming over tonight.
Clare
Thanks for your input. Again, switched at the fuse box and no response. This range is brand new - installed this past July. Plugged in at the back. Any other ideas? Clare
we were able to light the stove manually with a match and have 60 gallons of gas at this point. I've altered tonight's party menu to be prepared on the stove and am running over to use a friend's oven for the rest.
