Question about Yard Machines Tecumseh 148cc Front Tine Tiller #21a 251e000
Need gas tank for yard small yard machine tiller have not been able to find one for less than $ 30.
4 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: ifound a Tecumseh Yard Machine Front Tine Tiller.
It sounds as if you still have Carburetor problems.
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked.
(If there is a small screen in the Carb., this can get blocked too. Make sure that it is clean as well.)
Reassemble and start. (If there is a small screen in the Carb., this can get blocked too. Make sure that it is clean as well.)
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Sep 09, 2010
vincob
  • 718 Answers
SOURCE: Have a Yard machine Tiller, believe the model #
I needs to be cleaned!! It's clogged up in there with old varnished fuel..Clean thoroughly!!!! Good Luck...
Posted on Apr 19, 2011
  • 5184 Answers
SOURCE: do all yard machine tillers use sae 30--can't find
Can you find the model number and the serial number on the tiller? This should be on the tine housing in a 2" by 3" plaque (on the top where it's unlikely to be damaged in use). If you can, then you can find the manual here:
http://www.mtdproducts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10500&catalogId=20500&langId=-1 .
I don't want to assume what weight of oil you should use because your model may be different than the one in my shed.
I hope this helps.
Posted on May 14, 2011
If you lent your tiller to your "know it all"
While having your brother buy you a new tiller sounds good, it just might not be practical or posible. So drain the fuel from the tank, fuel lines and the carb., clean the spark plug and replace fuel filter if installed. Put the proper gas in and start it, should be good or clear up pretty quick. Hopefully it did not run with the wrong fuel for too long where the spark arrestor in the muffler would get clogged up.
Good luck.
If really helpful, please rate.
Jul 13, 2011 | Yard Machines Tiller 208cc 18in Tilling...
I HAVE A 2009 FRONT TILLER 500 SERIES. RAN FINE LAST YEAR. THIS YEAR STARTS AND STALLS. NEW PLUG, OIL IS OK.AIR FILTER IS CLEAN. IT HAS A FUEL PROBLEM. I CAN GET IT TO STAY RUNNING WITH THE PRIMER.DOES IT...
There are a few things to look at.First and easiest is check the primer bulb and fuel line for any cracks,and the in line fuel filter.Next is a filter on the end of the fuel line,inside the tank.If all of that is ok there is a small screen in the carb. you will have to tear down the carb to get it.
May 14, 2011 | Mtd Products Yard Machines 158CC Tiller
Ifound a Tecumseh Yard Machine Front Tine Tiller. It has a 5.50 HP. The tiller seems to choke out every time i crank it up. Can Someone tell mewhere the fuel filter is located???? i have replaced the air...
Just let me know.
Jim
Sep 05, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Just helping someone who put gas in her oil fill. What do I need to refill oil? SAE 30 ?
Yes, the Tecumseh engine takes SAE HD30 motor oil. With a complete drain, it should take about 21 ounces to fill.
Aug 26, 2010 | Yard Machines Tecumseh 148cc Front Tine...
5 hp briggs and straton starts then stops after 30 sec. to a minute. It has no points
chances are your fuel systom is dirty or you have water in your tank. or both
Jul 04, 2010 | Mtd Products Yard Machines 158CC Tiller
Starts but doesn't stay running
carb needs cleaning and also replace air filter
May 15, 2010 | Mtd Products Yard Machines 158CC Tiller
Fuel line routing yard machine 31cc cultivator 21A - 120R000
unit with primer bulb,,,,,line from gas tank with filter, goes to bottom of carb, from top of tank to suction side of primer bulb, from output of primer to tank return
Apr 29, 2010 | Yard Machines Cultivator
Carbartor
You need to pull the carburetor off and rebuild it.While your at it pull the gas tank and clean real good. Clean and blow out all the gas lines . Refill gas tank and put in a small amount of dry gas, read the dry gas label. Hope this helps. donnyb60
Mar 22, 2009 | Yard Machines Garden
5 hp Briggs and stratton wont run on a MTD tiller.
I had the same problem a few years back. Check the rubber elbow coming from the gas tank to the carb, it's probably cracked and sucking air instead of fuel from the tank.
Nov 30, 2008 | Garden
Yard Machines Tecumseh 148cc Front Tine Tiller #21a 251e000 Logo
19 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
