Question about Refrigerators
All fruit in the bottom most tray gets frozen
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 17, 2010
I have the admiral designer series HMG21149 refrigerator and I need the glass that goes on the bottom shelf over the veggie and fruit trays.
go to the service dealer spares for one
if it is no longer available go to appliance repair shops and ask if there is one from a fridge unit going to the dump
Jun 22, 2016 | Admiral Refrigerators
Freezing fresh strawberries
wash. take off stems cut them into halves or quarters , place into zip lock bags or a sealed container. pop into freezer. easy !
you can blend them and put into a ice cube tray as a great way to add flavour to a fruit smoothie - keeps it cold without watering it down.
Mar 25, 2014 | Cooking
CAN FRUIT BE FROZEN?
Yes, all fruit can be frozen in either freezer bags or tupperware containers and then cooked from frozen also.
Apr 01, 2013 | Kitchen Appliances - Others
I have a Kenmore Model # 253.62812202 refrigerator. It collects water at the bottom of the vegee and fruit trays at the bottom of the refrigerator which eventually leaks out onto the kitchen floor. Does...
It has a clogged drain tube and bottom trays is already full.
De-clogged it using a solid wire, match enough to penetrate the drain tube.
Insert solid wire slowly to the drain tube, back and forth.
Put water to clean and rinse drain tube.
Regularly check drain tube for clogged and tray for full water.
Good luck.
Jun 27, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Water is leaking into the inside of the refrigerator and pooling on the bottom under the fruit and vegetable trays
Just had an engineer round with the same problem and it was the drain that had frozen causing the water to build up. defrost the drain and this should work.
Jan 28, 2011 | Refrigerators
We have recently purchased a Coopers halogen oven. I cooked a frozen fruit pie in it and the pastry looked beautiful, but when it was cut open the middle was cold and the pastry under the fruit not cooked....
Frozen food should be defrosted before cooking in halogen ovens.
Halogen ovens use only radiant heat and will not cook the centre of frozen food.
Jan 21, 2010 | Ovens
Bottom drawer of the refrigerator freezes the fruit.
I think the thermostat is faulty. Thus it makes the freezer extra cold. Try replacing it. Regards, Nandini.
Sep 07, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
When trying to blend things like frozen fruit or frozen yogurt with the Vitamix, the blade stops moving, but the motor continues running. Even if there's only enough frozen yogurt to cover the blades, it...
Frozen elements are generally not recommended for blenders of any brand. They may cause the blade assembly to stop moving completely, or to "bog down," and this may eventually damage the motor. It is recommended that frozen fruits and/or yogurt be thawed when possible before placing into a blender. If this is not a possibility for you, I would use a "pulse" or "chop ice" function to rapidly spin the blades for just a moment. This will chop the contents in smaller, more manageable parts. This should be done before adding other liquid ingredients.
Jul 09, 2009 | Vitamix Blenders
Bottom of freezeer and fridge are cold, but top areas aren't?
you have defrost problem or check see if condenser fan working
Apr 07, 2009 | GE Refrigerators
Frozen food in refrigerator
turn your freezer up all the way and your refrigerator down a little. this will block some of the airflow going to the refrigerator.
Jul 05, 2008 | Amana Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
