FixYa.com
Tags:
Nikon Speedlight SB-600 TTL Flash
Flash not charging
posted by Ron in LA on May 17, 2008
Hi, thanks for your expertise.
Two symptoms...
1) Doesn't charge capacitor, no whine, flash ready no longer illuminates.
2) After the flash is on for a while, lcd displays 'bat' even though I swap batteries to known good units. It stopped charging after a time of heavy flash use.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 17, 2008
Not Rated (0)
jerryg50
Rank:Wiz Wiz
Rating: 84%, 455 votes
It sounds like the inverter circuit or the control processor may have failed. This is normaly changed as a complete module.
Nikon, or their authorized service rep should be able to service this flash for you unless the parts are obsolete.
Jerry G.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Flashes problems?
Nikon SB600.
Hi, I read your post about your... Answer This...
no TTL information for Sb-600
The autofocus light on the... Answer This...
nikon SB600
Flash ready light appears... Answer This...
SB-600 body is broken
I have a SB-600 plastic body is... Answer This...
SB-600 won't flash
Hi, I have dropped it , after... Answer This...
Repair Service
Find Flashe Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
