Question about Canon PIXMA MP830 All-In-One InkJet Printer
The printer will not power on. Everything is plugged in correctly. Any suggestions?
  • 30 Answers
Check the wire properly.sometimes the wire might be damaged .be sure that the power reaches
Posted on Sep 17, 2010
  • grgsolito Sep 18, 2010
    We bought a new wire and we are still having the same issue.
Hp f4435
I'm assuming you have the correct drivers loaded and correctly configured.
Set power switch to off.
Unplug it for 1 minute.
Plug it back in.
Turn it on.
If it still won't work, I suggest replacing the power supply.
If it still won't work, I suggest you replace it.
Apr 14, 2014 | HEWLETT-PACKARD Office Equipment &...
I replaced the black ink cartiridge now I try to power up printer and it wont power up what do I do?
First you can make sure the outlet you plug your printer into has electricity by unplugging the printer and plugging in a lamp or something to show the electricity is working. Unplug the other end of the power to the printer if it will unplug - so the printer power cable is unplugged at both ends.
If the electricity is okay then plug both ends of the printer power cable back in and see if the printer comes on. If it does not, lift the lid where you replaced the ink cartridge and see if you can remove and reinstall the ink cartridge. Make sure the latch holding the cartridge is firmly in place. Finally, make sure the lid is down and solidly in place.
Usually one of the above suggestions corrects the power problem. If not, please come back & remind us you have followed these suggestions and we can continue to try to correct your problem..
Good luck.................................Pete
Jul 22, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Lexmark x4650 hi, I have plugged a in the printer, nothing happening at all , no indicator lights, it has suddenly died , last used it a couple of weeks ago , any suggestions ? thanks
Verify that the power cable is firmly connected into the printer. Plug the printer in to a different outlet, one that you have confirmed works (plug in a lamp to verify that the outlet works). You may plug in the printer without the computer connection to test this. Check to see if the printer has an additional power switch on the back near where the cable attaches. If the problem persists, verify that the voltage is correct with a multimeter. The output voltage should correspond to the DC Output value written on the adapter. Confirm that this voltage matches the DC voltage required by the printer as written on the underside model placard on the printer. If the voltage is incorrect and the adapter is the correct one for the printer, replace the power adapter. If the voltage is correct then there is a problem with the printer that requires repair service. You may want to consider a new printer if this one is not covered by your warranty.
Apr 02, 2011 | Office Equipment & Supplies
Printer is dead
Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Leave the other end of the power cord attached to the power outlet. Bypass any surge device or power strip, plug the power cord straight to the power outlet in the wall. Properly secure the power cord in the power adapter. There should be green LED light on on the power adapter. Plug the power adapter back in the printer. Make sure it's plugged in securely and in the correct position. If it won't power on automatically, press the power button. If that doesn't help, it may be a hardware problem. If that's the case, I suggest you contact Lexmark Technical Support to further investigate the problem.
Jul 15, 2010 | Lexmark X2600 InkJet Printer
Lexmark 2350 seems to have no power
Try this. Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Make sure the other end is plugged in straight to a known working power outlet in the wall. Bypass any surge device or power strip. Properly secure the power cord in the power adapter. Then plug it back in the printer. Plug it hard and in the correct position. If it won't power on automatically, press the power button. If this doesn't help, I suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jun 22, 2010 | Lexmark X2350 All-In-One InkJet Printer
HP OFFICEJET 7210 all in one printer is diplaying carriage jam and check right cartridge. I have the manual and done everything suggested but still not working. the display still shows the same . anyone...
Please perform the steps provided in the following web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&cc=uk&lc=en&dlc=en&product=391153
If the issue persists, please perform:
1. Unplug the power supply from the wall outlet.
2. Unplug the power supply from the back of the printer.
3. Wait at least 20 seconds, then plug in the supply back into the wall outlet.
4. Plug in the power supply back into the printer.
5. Press the power button to turn the printer on.
If the issue persists, please replace your printer, as this is a hardware issue.
:) Dr Tony
Apr 20, 2010 | HP 7210 OfficeJet All-In-One Printer
My printer wont work. Its on and everything is plugged in correctly why wont it print it was just fine yesturday.
Turn the printer off. Disconnect the power-cord from the wall-outlet.
Turn the computer off.
Reconnect the power-cord & turn the printer on.
Turn your computer on, and try again.
Nov 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
Was printing fine. I turned the printer off and it won't go back on. Everything is plugged in correctly.
Possible hardware failure, unfortunately.
Turn it off. Then unplug it from your computer and unplug it from the wall too.
Plug it directly into a working power source. Then turn it on.
May 03, 2009 | Epson Stylus Photo R800 InkJet Printer
Hp PSC 1610 all in one printer
I may need a little more information to understand the exact nature of the problem. First, it sounds like the printer worked normally until the computer was rebooted, and then it stopped working completely...is that correct?
Do you get any error messages, either on the printer's display panel or on your computer? There should be a printer icon in the bottom right corner of your computer's screen. Does it look "normal" or is there a yellow triangle with an exclamation mark in it?
Frankly, rebooting the computer shouldn't result in the printer becoming completely non-responsive. My first suggestion would be for you to unplug the printer's power cord, wait about 10 seconds, and then plug the printer's power cord back in. Leave all of the other cables attached (USB connection to the computer and such). Make sure the computer is on and running while you do this.
Let the printer completely power up. It has to go through a start up routine, more or less the way your computer does. See if you can get a connection afterwards. Sometimes a glitch will occur and rebooting the printer will clear it.
If this doesn't do the trick, please post back more details about the nature of the problem. Thanks.
Oct 07, 2008 | HP PSC 1610 All-In-One InkJet Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
21 people viewed this question
old marine
old marine
