Question about Xerox Phaser 8200 Laser Printer
I have a service fault code, 07.005.47:43432 on my printer.
    Brigadier General:
  • 3,917 Answers
Hi
Please check the manual for the fault code:-
http://www.retrevo.com/support/Xerox-8200-Printers-manual/id/1305ag203/t/2/
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Sep 17, 2010
How to fix fault of WC 5330 bearing fault code 116-365
I have left you a attached link for service and trouble shooting information. However, I have not been able to find your fault code 116-365.
If the unit is listing a Bearing fault code, you may have to have unit serviced. See attached link below
May 27, 2014 | Xerox Office Equipment & Supplies
My Machine Xerox Workcentre 7328 getting a fault code 062-393
Fault Code 062-393: Scanner Control Board Failure. Power off. wait 1 minute. power on. if still broke call for service - 1-800-821-2797.
Oct 20, 2010 | Xerox WorkCentre 7328 Multifunction laser...
System fault code 10-389 won't clear
Hello.
System Fault Code 10-389 refers to a Fuser Nip Contact Failure.
To service the Fuser Nip Failure problem, you'll need a specialized laptop called a PWS (Portable Work Station).
So, unfortunately, this problem needs to be handled by a professional service tech.
Hope this helps.
Hope this helps.
Customize: Reply 1: XEROX DOCUCOLOR 12 :: Xerox - Color :: The Copier Network"" src="/images/cust_r0.gif" border="0" height="13" width="15" />
Sep 15, 2010 | Xerox DocuColor 12 Printer
Our xerox workcenter 7235 fault code 024-360 and copy service is disabled
024 360 An error has been detected by the Controller during communications with the Printer. User intervention is required to Power Off/Power On the machine, Field Service is required if the problem persists. Printing is disabled.
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC7228_WC7235_WC7245&Xlang=en_IN&Xcntry=IND
You will have to either get this printer repaired or replace it.
Aug 05, 2010 | Xerox Office Equipment & Supplies
0630 Fault code on KM 5035
you have a defective main PCB. you should contact your nearest service agent
Mar 13, 2009 | Kyocera Mita KM-5035 Printer
Error code 09,038,46:21303
When you service a Phaser 8500 or 8550 printer for:
· a persistent Ink Out message
· 9,035.43 Cyan Ink Stick Count Fault
· 9,036.44 Magenta Ink Stick Count Fault
· 9,037.45 Yellow Ink Stick Count Fault
· 9,038.46 Black Ink Stick Count Fault
Test the Ink Out Sensors for proper operation.
Inspect the Ink Sticks.
Apr 09, 2008 | Xerox Phaser 8500/DN Printer
Cannon D780 All in One Laser Printer System Error 000
System error 000 means a fault occured 4 times in a row. You can reset this fault code and the copier should start working again. I assume you had other fault codes before you received this one, otherwise you would of never got the 000 code. To reset this code, you need to go into service mode. I dont have the instructions at this very moment, but I will get them and post them tomorrow.
Oct 05, 2007 | Canon imageCLASS D780 All-In-One Laser...
For coding solition
Fault relates to heating problem within Fixing assy, fault will not reset by switching machine off/on. Try to reset error in service mode. *, 2&8, *, COPIER, FUNCTION, CLEAR, ERR, press OK. Reset machine.
Aug 20, 2007 | Canon imageRUNNER 3300 All-In-One Laser...
Xerox Phaser 8200 Laser Printer Logo
21 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
