Question about Eureka 5856BVZ Boss Bagless Upright Cyclonic Vacuum
Behind the brushs, there appears to be a plastic part (tube) that is broken. Is this common and/or easily repaired?"
  • 33 Answers
The tube you see, is just the underside of your height adjustment knob. It may look jagged, but it is not broken.
Posted on Sep 26, 2010
I think the belt is off or broken in the cleaning head, but need to get it apart and don't know how
It appears to be the same cleaning head on my model # 116, if so, there are two phillips screws underneath that must be removed. Also remove the two phillips screws on the collar above the head where the wand tube enters. Then there are four plastic retention clips that can be released with a flat head screwdriver. When lifting twist the collar assy that remains on the cleaning head to allow the top plastic cover to come away from the cleaning head. Once off, th brush and belt are easy to access.
Feb 13, 2011 | Kenmore 23913 Progressive PowerMate Bagged...
Will not spray
There are a handful of places that the mechanism can get blocked. The easiest test is to remove the brush attachment and pull the trigger. If it sprays fine, then the blockage is in the small length of tubing in the brush attachment. The most likely place is in the small plastic piece at the very end of the attachment. You should be able to see the small plastic piece where the tubing ends, this is a common place for a blockage. You can usually use a piece of thin wire to clear the blockage.
Nov 28, 2010 | Bissell 1425 Little Green ProHeat Handheld...
Won't spray, only dribbles
There are a handful of places that the mechanism can get blocked. The easiest test is to remove the brush attachment and pull the trigger. If it sprays fine, then the blockage is in the small length of tubing in the brush attachment. The most likely place is in the small plastic piece at the very end of the attachment. You should be able to see a small plastic piece where the tubing ends, this is a common place for a blockage. You can usually use a piece of thin wire to clear the blockage.
Nov 12, 2010 | Bissell 1425 Little Green ProHeat Handheld...
I have a Ultima 12 amp e10071, The brush is not turning, there is tension on the brush as if the belt is connected but still there is no rotation. The motor does run. How cani open the vac to take a...
You get to the belt & brush roll area from the top. On the hood of the vacuum, right behind the word Altima, to the right & left sides, you will see a screw. Remove them, lift off plastic hood. Check belt if broken or just stretched too big to catch brush to turn it. Check ends of brushroll for any hair, thread buildup & clean it. See if end caps turn easily. If one or both ends do not turn easily, the brush roll would need to be replaced.
Eureka Brush roll part # 62365-3
Eureka U belt part # 61120D
Sep 01, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Jun 30, 2017 | Hoover Vacuums
Stand up lever is plastic, broke when stepped on to release handle, can it be repaired, replaced with a better one, plastic breaks too easily?
The pedal release can be replaced but the base will need to be checked for cracks as well. if the base is broken most common is the socket the pedal release snaps into. some of the plastic parts have been made with better materials
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 20, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
My Hoover steam vac dual v's brushes will not spin and the square that the peg goes into wont spin either. There is suction but it is making a loud noise.
sometime when the brush is not turning their are less resistance to the motor, so it will turn allot faster than normal. The turbine gear assembly which connected to the brush assembly probably broken, all the gears are made out plastic and they can easily break,strip or worned over period of usage. the assembly cost around 20 bucks and it not that hard to replace and it not that hard to take it apart, just remember what goes where. I wonldn't surprise when taking the vacuum apart as you observed closely and inspect the brush unit and the turbine gear assembly you might easily spot what broken and need replacing. hope that help some; and if you don't want to fiddle with it, your local vacuum repair guy can probably do it for less than 40 bucks. you can go on-line vacuum parts.com
Oct 04, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
There is no suction to the floor sweeper. The
Sounds like you have two separate problems here.  If the brush bar does not rotate, probably the belt is broken. This is easily replaced, but you need to be precise about which model you've got so you get the right belt.
Loss of suction is due either to a blockage or, quite often, to a split in the short length of clear plastic hose that leads back from the brush bar enclosure.  Repair is possible but replacement is better.
If you need more help, post here again.
Apr 21, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Hoover 5470-900 no longer contacts carpet with beater brush
your floor adjustment spring is broken there is a plastic slider and clip if it is broken the height adj will not work you should get a new vacuum because this repair can cost as much as a new vac.also this is a common problem with the hoover brand I would get a sebo or an oreck they have a great warrentty and you will more than likly never buy a other vac.
Jan 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Eureka 5856BVZ Boss Bagless Upright Cyclonic Vacuum Logo
132 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
